Will not print from explorer
frankcc
I need some help please. I have Vista Ultimate SP1 and after having the system running for a while I lose the ability to print from internet explorer. I get the a windows internet explorer error box indicating that it cannot find 'file///C:Users/Frank/AppData/Local/Temp/Low....... Make sure the path or internet address is correct. Later I get a script error box. When I reboot I regain the ability to print from the internet and then when I really want to print something again the error returns. I have a very basic stand alone setup (no LAN) with hard wired Verizon Fios and a router. I have HP computer and printer. Any help would be greatly appreciated. Well I need to reboot again.
You're welcome Frank. Please let us know how it went for you.
Shawn: It did not work. I used the command: icacls C:\Users\(Frank)\AppData\Local\Temp\Low /setintegritylevel (OI)(CI)low and tried it without the () around the name. Message received "the system cannot find the path specified".
You will need to create a new folder named Low first at the C:\Users\Frank\AppData\Local\Temp location first, then do the icacls C:\Users\Frank\AppData\Local\Temp\Low /setintegritylevel (OI)(CI)low command.
