bassfisher6522
I just got my Wii back yesterday. I had to send it off for repair because my son (3 years old) decided to put in some playing cards and a box top lid. My problem is that before I sent it off for repair I could connect to internet just fine. Now I can connect as before because my routers wireless security is disabled. I set up the router that way on purpose. Now I want to enable the wireless security, WAP Personal, which I did and reconfigured all laptops, everybody can connect. Now, when the Wii tries to connect I get error code 51030...that tells me that there is now WI-Fi access for it to pick up. If I disable wireless security it connects just fine. So, How do I keep my wireless WAP personal enabled and still be able to have the Wii connect as well. Any thoughts?
- Self built
- AMD Athlon 64x2 6000+ 3.0ghz
- Asus M4N78 Pro
- 3Gb PC2-5300 DDR2 @ 667mhz
- XFX Radeon HD 4770 512mb GDDR5
- VIA HD Audio
- Dual monitors: HP W1907 LCD 19" and Gateway HD Display 19" LCD
- 1440x900
- Barracuda 7200.10 SATA 3.0Gb/s 320 x 2-GB Hard Drive
- PSU
- Antec Earthwatts 80 plus 500 watts
- Case
- Ultra E-Torque ATX Mid tower clear side w/2 120mm fans
- Cooling
- Thermaltake MaxOrb cpu cooler w/120 mm blue led
- OEM HP
- OEM HP
- Download 6885 kb/s upload 367 kb/s
- Other Info
- Optical: Super Muliti DVD burner w/lightscribe, Hauppauge WinTV HVR-1800
