My laptop will connect to the internet automatically upon startup and works fine but I'm just wondering why the little wifi light on the bottom left hand side under the keyboard never lights up. It will do it if I manually turn it on by pushing F2+FN.....just curious if it makes any difference (I havn't noticed anything) and if there is a way to set it up correctly.
- ASUSTeK Computer Inc.\N80Vb (Socket 478)
