Hi all.
I have looked around the forum and found some posts with kind-of the same problem, just not the same.
By PC starts up fine, and i sign in. It does not take any longer then usual. Then, my icons disapear and the screen turns white. I can see my cursor, but not right-klick. I can use Ctrl-Alt-Del, and enter the interupt screen, but i CANNOT open the task-manager, a feat available to the other posts conserning the same problem.
I've tried to restart in safemode. I've tried to remove all USB devices.
When i Ctrl-Alt-del and choose either of the shut down/rest/sleep/restart options, my icons reapear, just in time for the log-off/shut down.
Any help will be greatly appreciated.
