Which x64 Wireless PCI card??
jb7_uk
Hi all,
Am having a complete mare with my wireless LAN since switching to Vistax64. It's not Vista's fault, it's a distinct lack of 64-bit support in the drivers from manufacturers.
Initially i had a cheap-o Buffallo USB dongle. No 64bit support from Buffallo, never was, never will be. No problem, probably about time i upgraded anyway.
So, i opted fro the Linksys WMP300N (v2) card as i will upgrade the router at some point in the future and the new Linksys routers have been getting good reviews.
This was my first mistake. I have spent pretty much all weekend trying to get this ruddy card to work. It just will not! I've tried linksys drivers, i've tried Atheros drivers (manufacturer of the chipset for the euro version of this card) but nothing works.
The closest i can get is the most recent linksys drivers whereby the system will see the card, and it seems to work - i can find my network, but as soon as i enter the Passphrase to connect, system locks up completely. no BSOD, just completely frozen. Only option is to hard reset. oh and then, 9 times out of 10, the system wont even boot fully, usually locking up at the circular win vista logo.
So, unless anyone knows of a working x64 driver for the EU (ver2, Atheros chipset) of this card, and can piont me in the direction of a download, the Linsys is going back to the store.
My question for you guys is...
Which PCI wireless adapter (preferably with an external antenna) can i get that will work in Vista x64. I will be looking to stream media over the network so a decent N-spec would be preferable. Tried and tested solutions would be best of all!
Many thanks in advance,
Jim.
    Home Grown
    Intel C2D E6400 @ 2.1GHz
    MSI P6N (680i SLi)
    OCZ DDR2 1066MHz
    2 x GeForce 7600 GT in SLi
    On board
    DELL 20" TFT
    1600x1200
    320Gb SATA II Maxtor
    620 ish WATT Hyper
    Lian-Li PC6070B
    16Mb ADSL2+
I hate anything to do with networking when it comes to drivers, they are always behind the times. I use a belkin f5d7001 as it uses windows drivers, it has 64 bit support. Its only a G+ card but serves me well. Might be a good cheap solution until 64 bit compatible drivers are actually thought of.
Belkin G+ Wireless PCI Adapter - Ebuyer
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
Hi Fieseler, cheers for the reply.
Funnily enough i've used Belkin gear in the past and found it to be nice and reliable but several of my colleagues have had nothing but trouble with recent Belkin products (i work in IT and have seen problems there too) but maybe i'll give a belkin product another go.
I was ideally looking for a PCI card with some kind of external antenna as PC is under desk which has panel ends so is effectively surrounded by wood on all but 1 side.
Do any of the Belkin N products have 64-bit support? Or does anyone else have any N-spec 64-bit friendly card recommendations?
Cheers,
Jim.
    Home Grown
    MSI P6N (680i SLi)
    OCZ DDR2 1066MHz
    On board
    DELL 20" TFT
    1600x1200
    620 ish WATT Hyper
    Lian-Li PC6070B
    16Mb ADSL2+
