Where is my e-mail going?
Bobh
I am using Vista Home Basic 32 bit. I use Yahoo mail. I have an e-mail I want to save. There is a place labeled "move..". If I click on that where does the e-mail go? The e-mail has attachment. Can you tell me a better way to save my e-mail?
Thanks Bob
you should have to pick a folder and than click on move and it will move it to the foldedr you specified.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Fadedrs -
Please bear with me. I don't know much more than how to turn this thing on and off. I have never done anything with folders and files. Give me instructions on how to create a folder to put my e-mail in that I want to save. Thank you. Bob
for your email do you use a program or do you go to yahoo and than check your mail?
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
If you're using a web service e-mail, there should be either a manage or add folders link you can click and add folders to your listings. Do you see something like that?
Cheers,
    Dell XPS M1330
    Intel Core 2 Duo
    3GB
should see something like this.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Thanks to all who replied. I am amazied!!! I found the file and put the e-mail in it for safe keeping. The folder must have been there all the time. I just did not know what In was looking at. I sure learn a lot from forums like yours. Thanks again. Bob
