Where is c1e setting!
Gamemaster2237
Hello everyone this is my 3nd post, i was woundering if anyone knows where to find the c1e in bios settings i cant find it anywhere in my bios
    Hewlett-Packard Comany a6200n
    AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ 2.60GHz
    Phoenix - AwardBIOS v6.00PG
    2.00 GB RAM
    HP w1907 Wide LCD Monitor
    1400 x 900 x 4294967296 colors
Hi Gamemaster2237,
It's under the "CPU Configuration". I'm attaching a picture of mine.
Cheers,
    Custom-Built Desktop
    Intel Core 2 Quad Q9550 OC to 3.4Ghz
    EVGA 780i Triple SLi
    8GB (4 x 2GB OCZ DDR2-1066 / PC2-8500 / Platinum Series)
    MSI nVidia GTX 295 SLi
    On board
    2 x ViewSonic VA2216w
    1680 x 1050 each
    1 x Samsung 750GB / 32MB / 7.200 RPM)
    Thermaltake TR2 1000W
    Thermaltake V9
    Thermaltake Mini Typhoon
    Logitech MX Revolution
    Logitech G15
    1 mb/s
cie is similar to speedstep.
I say similar because it is not the same, there are two settings.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
i think ''CIE'', will step your core voltage down when idle, whereas ''Speedstep'' will step your ''multi'' down while idle....;)
but as said above the option is either under... CPU or ADVANCED OPTIONS
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
technically they both do the same thing , this explains better than i could :P
C1E - Enhanced Halt State
"Whenever the OS executes the halt instruction, the CPU enters what is known as the halt state. Architecturally, what's going on in a halt state is the clock signal is shut off to the CPU for some period of time. With no clock signal, none of the logic in the chip will do anything and thus power consumption is reduced. Performance is also significantly reduced; however, the halt instruction isn't usually called during application usage, so the performance aspects of the halt state aren't very important.
The problem with the halt state is that it does nothing to reduce voltage, only current draw by stopping clocks from going to the CPU. Since Power varies linearly with both current and voltage (P = I * V), you're effectively only addressing half of the problem. The Enhanced Halt State, as Intel calls it, does two things: it reduces the clock speed of the CPU by decreasing the clock multiplier down to its minimum value (on the EE 965 series, that's 14x, or 2.8GHz), then reducing the voltage. The clock speed is reduced and then the voltage is dropped, to maintain stability.
Intel insists that the enhanced halt state is a significantly lower power state than the conventional halt state, thanks to the reduction in voltage in addition to the reduction in clock speed. While the standard halt state causes a linear reduction in power, Intel's enhanced halt state causes an exponential decrease in power, potentially offering better power savings than the standard halt state. The real world impact obviously depends on how idle your system happens to be."​
EIST:
"What EIST does is very similar to AMD's Cool'n'Quiet. It is demand based reduction in CPU clock speed and voltage. Using the same mechanism of adjusting clock speed and voltage, based on the application demand, the processor will dynamically increase/decrease its clock speed between its minimum clock and its normal operating frequency, as well as voltage, in order to optimize for power consumption.
Because of the way EIST (and AMD's Cool'n'Quiet) works, there's inherently a drop in performance. The idea is this: if you're performing a task that's not using 100% of the CPU, the CPU will operate at a slightly reduced frequency in order to conserve power. So, while some tasks will require that the system run at full speed, others will run at lower speeds. "​
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
:(Sorry guys I check its not under Advance options or CPU Configuration
    2.00 GB RAM
Darn... I just booted to check it again and it is there. Where did you get your current BIOS Firmware from? What brand is your MOBO? Maybe that brand in particullar has it hidden or something (I've seen it before in branded BIOS). Try and get the latest BIOS Firmware update (same version up untill today) but from somewhere else.
    On board
    1680 x 1050 each
    Thermaltake V9
    Logitech G15
    1 mb/s
