You should upgrade or use an
alternative browser .
what is this about please help
volsnap event 57 task 2 i have just had 300 of these come up why its messing my computer around aaaahhhhhhhhhh help please some one thank you
Plays with his WEI
I don't see anything directly related to that error code in the Microsoft support database.
Search The Knowledge Base
I believe it's related to backup/shadow copy, but I could be incorrect on that....
Proudly Built by Me!
Intel Q6600
DFI UT LP P35 T2R
8GB OCZ Reaper DDR2 800 C44GK 4-4-4-12 2T
Sapphire Radeon 4870x2
AuzenTech Prelude 7.1
1 Acer P243 24" and 1 Samsung T260 26" Monitor/HDTV
Both are running at 19x12
Seagate 1TB 7200.11 (Vista x64)
Seagate 500GB 7200.11 (Win 7 x64)
OCZ GameXtream 900w
FSB at 400 (1600) Mhz, CPU Multi @ 8 for 3.2Ghz
Hi VeryUnhappy,
Is there more to the error message?
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
hi there all the message is saying is... the system failed to flush data to transaction log .corruption may occur but i have had hundreds of them ,why.. thanks for your help
VeryUnhappy,
I did a Google search on this, and some folks report that restarting the computer cleared the error for them. Yo might give it a try to see if it can be this simple for you.
You can also look in the
Event Viewer logs and the
Reliability Monitor to see if anything stands out that may be the cause of this error for you to. This tutorial can help you on the Reliability Monitor.
http://www.vistax64.com/tutorials/69535-reliabilty-monitor.html
Operating System
Operating System
