What is the first step to diagnosing a problem signature?
ellsworth2000
Hi There,
I'm trying to figure out what to do with my problem signature:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 1000008e
BCP1: C0000005
BCP2: 90822941
BCP3: ACAB4A1C
BCP4: 00000000
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini120109-01.dmp
C:\Users\Kevin\AppData\Local\Temp\WER-53196-0.sysdata.xml
C:\Users\Kevin\AppData\Local\Temp\WERE187.tmp.version.txt
Only the Mini120109-01.dmp can be found on my computer. The other two I cannot find even with hidden files/system files set to viewable. Event viewer seems to have alot of errors for the i8042prt driver but I don't know if that is causing this problem signature.
Any advice would be helpful.
Many thanks,
Ellsworth
    AMD
Hello ellsworth2000,
Go to C: Windows > Minidump, zip up the files and upload them with your next post, and we will do our best to find the problem for you.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I've uploaded the Mini dump though i swapped my keyboard and mouse with a keyboard and mouse that have PS2 connections on them and i'm not having the issue anymore.
many Thanks,
Ellsworth2000
    AMD
Looks like you have fixed your own problem.
Chances are it was a driver, is there anything in the "Event Viewer" ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
