What is the best way?
I don't know if you could have possible asked a more open-ended question. "Best" is a matter of personal choice. Most people use an external hard drive, and some prefer a backup service.
As Archpope said, you could not have asked a more open-ended question.
You could just use a program like Nero to write only pertinent data to CD or DVD. Should your hard drive fail, this type of backup will still require you to install a new hard disk, re-install Windows and all other applications, and then copying the data back from CD or DVD.
Another solution would be to use Windows Backup, which can create a complete image of your hard disk. Should your disk fail and need replacing, you will still need to reload Windows in order to use Backup to perform a restore.
There is a third party solution: Acronis True Image. Like Windows Backup, you can use it to create a complete image of your hard disk. Restoring the disk in case of failure is easy. Just boot from the CD or DVD, and run the restore to get your computer back to the state it was in since your last backup, and then continue working as though nothing has changed.
You can get Acronis here: Backup software for data backup and disaster recovery in Windows and Linux - Acronis
But again, it really just depends on how you want to be able to restore your data, and whether you want to be able to recover individual files (in case of accidental deletion) or if you want to create your own recovery disks.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Personally I would go for a USB harddrive. You can update the backup as you work on your current drive and take the data too any computer with a usb port and compatable os.
I have backed up data onto dvd that I know will not change much but as you do a one backup the old dvd become redundant.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
