Has anyone had experience with compatability mode. I am a new Vista Premium user and have not seen this program.
Possibly related, sometimes after a straight install and the "Finished" button comes up, I get a message to the effect "This program may not have installed properly, do you want Mr Vista to do it again properly?"MrHope said:Some installers and/or programs will require admin mode. I use admin mode for all of my installs just to be safe.
Under Windows Vista, even an administrator normally runs with standard user privileges. Only when access to certain key areas of the system are required, does Vista prompt you for elevated privileges.
Microsoft has been crying themselves hoarse for the last 10 years about the proper way to write a Windows program! Programs should not write stuff to certain parts of the registry that are not accessible without admin privileges. Most software companies have been guilty of writing crap that assume that all users on a Windows pc have admin privileges. This is the first time that MS is actually enforcing the rule.
What Vista is attempting to tell you when it says that the program may not have installed correctly is that the program was written pre-Vista and may require admin privileges to install. This is particularly the case if it is not using Windows Installer technology and is attempting to access the HKEY_LOCAL_MACHINE registry key.
For programs such as these, it is best to start the SETUP.EXE as "Administrator" by selecting the program, right-clicking and selecting "Run as Administrator".
I'm getting reconciled to the fact that a lot of my little utilities picked up over the years for XP, even 9x, just aren't written "good enough" to satisfy Vista. Time to find new ones...If you believe it installed ok and is running fine, then I would just ignore the standard message from Vista.
