What card - 9800GTX+ or GTX260
admles
As I said in an earlier thread, my 9800GX2 is having serious heat problems; the retailer has told me I can return it and exchange it, so I will be getting a different card and getting another HDD with it.
What should I get - 9800GTX+ or GTX260?
I am after gaming performance - Far Cry 2, Sacred 2, Crysis etc. I also prefer nVidia over Ati, which is why I chose those two cards. I want something thats never going to give me overheating problems like the 9800GX2 is!
    Intel E8400 CPU
    Asus P5N-D
    4gb (2 x 2gb) DDR2
    Gigabyte 1gb 9800GX2
    Sound Blaster F4tal1ty
    Samsung 22" LCD
    1680 x 1050
    1 x 150gb Raptor SATA-2 2 x 750gb Western Digital SATA-2
    730w Antec TruePower
    CoolerMaster CM690
    Logitech G9 Laser Mouse
    Logitech G15
GTX260 FTW!!
see if you can get the 216SP model & that card will play anything currently out & anything coming out in the next few years @ MAX settings
if you have been powering the GX2 then Amps wont be a problem.
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
if you are going to get a graphics card between these 2 then get the 260gtx, but get a factory overclocked card, i got the xfx 260gtx xxx and its sweet as a nut, runs crysis max dx10 at 1920 x 1080 at about 20-30fps. if i wanted a faster framerate, all i do is drop the res to 1280 x 720 and its got about 30-40fps. but i got a 3-way sli mobo so i may just get another one and bump performance up about 40%
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Well if you were going for a 9800GTX from a GX2, you'd be downgrading...so a GTX260 is the better option.
What temps have you been getting with your GX2?
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
It gets upwards of 110 degrees celsius and shuts down.
    Intel E8400 CPU
    Asus P5N-D
    4gb (2 x 2gb) DDR2
    Samsung 22" LCD
    1680 x 1050
    CoolerMaster CM690
    Logitech G15
damn thats hot, is that under load? i think you need to change GPU or get an aftermarket cooling system, well the 260gtx in my system idles about 46-50 degrees celciusand under load is about 60-70c, heres a pic to prove it, mind you the cool temps may be because of the casing. (antec 900)
    16Mb Sky bb
Nice.
I have a Coolermaster CM690, plus the room is air-conditioned; I think the card is faulty, because when I first got it I could play games for hours without a problem, it just gets worse and worse now.
    Intel E8400 CPU
    Asus P5N-D
    4gb (2 x 2gb) DDR2
    Samsung 22" LCD
    1680 x 1050
    CoolerMaster CM690
    Logitech G15
lol, simple answer, clean the fan!
    16Mb Sky bb
The whole system gets cleaned out with compressed air once a fortnight
    Intel E8400 CPU
    Asus P5N-D
    4gb (2 x 2gb) DDR2
    Samsung 22" LCD
    1680 x 1050
    CoolerMaster CM690
    Logitech G15
canned or shop pressurised?
    16Mb Sky bb
none the less i use a very fine paintbrush and it does a damn good job of cleaning out any fans i have, it just sounds like your fans have clogged with grease and dust. you need to get a second opinion or change your card.
    16Mb Sky bb
My father has a big compressed air blower, it's awesome!
In any case, the fan is clear, it's one of the first things I checked.
    Intel E8400 CPU
    Asus P5N-D
    4gb (2 x 2gb) DDR2
    Samsung 22" LCD
    1680 x 1050
    CoolerMaster CM690
    Logitech G15
