fieseler
I dont know where else to post this but id like to see if i can fix this so i dont have to rma my motherboard & spend ages without my pc.
I like to keep my pc clean so every couple of months i like to clean out the filters on my fans. Obviously i have to remove some fans to get at them. Occasionally tho, my pc will not boot afterwards. I thought it might have something to do with removing the fans too often.
Dunno what might be ausing this but i used to be able to fix it by resetting the bios by removing the battery, but last time i fixed it by booting with not ram installed. (i know its no the ram causing this as i recently changed it).
I'm no electrical expert but i might have this figured out; to get the side panel off completely, i have to unplug a fan from a 3pin to 4 pin adapter which leaves a 10cm wire with the 3 pin prongs exposed which may touch the the bare metal on the case. Could this cause some kind of short out that would affect the bios or something?
- §ĮŁΣNŦ Д$$Д$$ĮN
- Xeon X3360
- P5W64 WS Pro
- Corsair XMS2 8gb @ 5-4-4-12 833mhz
- EVGA Geforce GTX470 SC+
- X-Fi Extreme Gamer Fatlity Edition
- Samsung T200
- 1680x1050
- WD 1TB RE3
- PSU
- Thermaltake Toughower 750w
- Case
- NZXT Lexa Silver
- Cooling
- Zalman CNPS10x Extreme
- Razer Deathadder 3500dpi
- Razer Lycosa Mirror
- 24Mb/s
- Other Info
- My massive wifi antenna is in the post!
