webcam and webpages problems...
blighty
i have recently bought an ADEVENT 9515 laptop which has AMD TURIONtm 64x2 TL60 2.0GHz 2GB ram and vista home premium VGA out 1.3M pixel webcam built in, etc etc but we have been having problems with our webcam, we had it working once, ever since then whenever we try to use it, it crashes our windows live messenger which is a shame to have it and not be able to use it. also we keep having problems with web pages loading, we keep getting "the page cannot be displayed" etc. sometimes if we flush the dns it works, but not all the time.
can anyone help me please as im not the most computer literate person.:(
when starting Live MSN Messenger do the Audio Web Cam Set up its in the drop down Menu at the top go through the setting before you connect if it allowes you some On Board cams have there own driver and setting's msn and yahoo useto share the same setting yahoo messenger had a test board to see you're default cam and we had to go into reg edit to do has setting for XP and they are the same settings in the compatible mode for vista reg edit.my friend in my Building here has an HP labtop and his web cam is built right into it he had to the same thing set the audio and web cam setting's before you signed in then shut it down check the right hand cornner of you're task bar to make sure Live messanger shut down if it didn't setting won't take effect you're live messenger migh come up with an error . try it it should help and also restart you're computer then open messenger test a cam meeting with a friend on line when you're computer restarts .
have just tried that, as soon as it get to the "select webcam" i click on the webcam i want to use and it crashes msn and it closes the program :(
