web pages wont display
case998
Hello, ive just set up my new net connection and although ive got access local and internet on my vista home premium 64 bit system when i try to connect to a web page i get a blank white page which says done at the bottom. I then connected an XP based laptop with no problems so i presume theres a problem with vista,any help greatly appreciated.
    acer aspire 6920
    intel centrino core 2 duo T5750
    4 gig
    intel x3100
    250GB HDD
have you tried with both ie and firefox
    Sony Vaio
    Intel Core 2 duo
    ATI Mobility Radeon™ HD 3400 Series
    1600x900
    400 GB
    Laptop
    DSL 2 Mbps in dec 16 yesssss
    We Can DO I.T.
yeh ive tried both them and google aswell so i think its a vista problem because its able to download updates from the net but carnt surf cause it opens a blank white screen. Thanks for reply.
    acer aspire 6920
    4 gig
    intel x3100
    250GB HDD
try and ping google from a command promt
    Sony Vaio
    Intel Core 2 duo
    1600x900
    400 GB
    Laptop
    We Can DO I.T.
just done that and it says its sent 4 packets and received 4 with none lost so its connecting but it still loads the about:blank page
    acer aspire 6920
    4 gig
    intel x3100
    250GB HDD
I have experianced the exact same problem, FF and IE stops displaying webpages but everything else works (mail, torrent, RSS etc etc). Both times was after an update and the only way I got FF and IE to work was to use the system restore feature. Vista64 said that the (this might be the wrong name for it I use Vista in swedish) Data Execution Protection something had blocked FF and IE due to something....I tried finding info on this but appart from a thread in a swedish forum I could not find any other information about this problem. As now I dont dare upgrading or patching Vista att all due to the fact that the last two updates has led to IE and FF refusing to display webpages.
