Web Cam Issue
gmez
Hi, I'm new to this forum and this is my first thread. I purchased my laptop, an HP pavilion dv6000 (that's whats printed on the screen), in Nov of 06 and received the Vista upgrade over the summer. As you all are aware of, I had a lot of problems. One that I could never fix was my web cam.
The web cam is built into my screen and worked fine before vista was installed. Once I installed it, it no longer worker. I attempted to download a driver but it never really worked and I kind of forgot about it. Under my Start>All Programs I have two folders with the following in each.
1. HP Pavilion Web cam>HP Pavilion Web cam...the second is also a folder and when clicked on the Start menu closes and that's that.
2. HP Web cam>Uninstall...I've unsuccessfully tried to uninstall and reinstall
Now I really want to use it with skype and can't fix it, can anyone help me?
Any help would be greatly appreciated...THANK YOU!!!!
Giuseppe
You'll need to find out from HP if there is a Vista driver available for it - more than likely that folder will still have the XP only drivers since your system originally came with XP.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Try to go to the Device Manager and uninstall the Webcam completely, then try to find some drivers on the HP site, or maybe across the Internet.
I installed my Logitech QuickCam Chat by uninstalling ALL of it, all drivers, all THINGS leading to it, then installed the last driver off their site, and voilà.
    Intel Core 2 Duo E8400
    ASUS P5B-E Plus
    4GB Kingston ValueRAM DDR2-667
    ASUS EN8800GT 512
    Creative X-Fi XtremeGamer
    Packard Bell Maestro 190W
    1440x900 @ 75Hz
    WesternDigital 200GB 7200RPM + Iomega Desktop HD 360GB 7200RPM
    Xilence Power 600W Gaming Edition
    Coolermaster Centurion 534 Black
    Standard Coolermaster Case Fans + Standard Intel CPU Fan.
    Razer Copperhead Tempest Blue
    Logitech G15 V1
    100.0 Mbps
