Wat should i do for better gamming
ericnel
Hi Everyone
I have a brand new cpu
-antec Twelve Hundred
-intel QX9650
-MSI N9800GX2
-4GB viper pc3-12800
-74 gb raptor velocity 10,000 rpm
-1000w thermaltake toughpower
and ...
the important is there i am running on vista64x but i like better win xp but only have 32bit software and xp takes only up to 2.5/3.5 gb depending on the machine and i would like to now wath i should do. Im lost and would like to get the best performance gamming for the stuck i buyed but without lowering my ram and ima be overcloking my cpu and ram
PS: I heard that windows xp server 2003 took up to 4 gb of ram but does anyone think i should change.
Thanks in advance.
Eric
    QX9650
    Stricker Xtreme 2 790i DDr3/1600mhz/1800mhz/2000mhz
    Patriot Viper Series pc3-12800
    MSI N9800gx2
    soudblaster 5.1
    raptor 74gb 10,000 rpm 250gb WD
    Antec Twelve Hundred
    gemin2 cooler
    100mb/s
I also like XP more than Vista, more so after all the problems with networking, etc, etc., 8GB's of 1066Mhz ram I don't want to waste. But I digress
I have Vista Ultimate x64 but more for regular or everyday use, honestly, I have it more for the wife than anything else. On the other partition, I have Windows 7 RC 7100 and so far, there is no game I can not play on it, I find it quicker than Vista and more stable.
Sure, it has its quirks but mostly, because it is different look and feel than what XP and or Vista are so I am still learning and understanding how to navigate thru it
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
thank for the advice
its late but ill post another post tomorow could u send me the link to llook it out for win7 cause ive saw it and did inded like it but never tested it i just got my psupply today so ima let it cool before modifing but ill post more tomorow thx and hope u repply
Eric
    QX9650
    MSI N9800gx2
    soudblaster 5.1
    gemin2 cooler
    100mb/s
I would stay with Vista x64, i love it and would never go back to XP, i have no problems and i dont have a game that wont run on it, it you want to ramp things up a bit overclock your Cpu, i have a QX9650 and it does make a big difference. Just my two bobs worth.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Thanks for the reply
i am going to try vista for a while cause i wont downgrade for nothing but for now its running fine and ive not come to ovecloack yet but i know its realy possible and further possible with striker 2 xtreme motherboar so i wont worry thanks again and ill give u new about my run time of won vista
thx for replying
Eric
    QX9650
    MSI N9800gx2
    soudblaster 5.1
    gemin2 cooler
    100mb/s
