Hi guys.. I have two computers. One with Windows XP Pro and the other with Vista ultimate. Both are behind a modem/router. I want to connect them through the internet, so that i can have a file share between them, like i am on lan. I have configured the Vista pc to be a server and the XP as a client. I do the following on vista. I create a new incoming connection, allow the users i want, and enable the "allow callers to access my local network" option in tcp/ip properties of the connection. I also port forward the TCP 1723 port on both pc's as well as GRE. So everything should be fine. When i connect from my xp pc with a vpn connection to the other, the connection establishes and on the vista pc, i can see it says one client connected and it pops up the new network wizard and shows the user i used to connect. However on the status of the vpn connection says, ipv4 connectivity, not connected. My problem is, that although the connection is established , the pc's can't see each other in network. What am i doing wrong? I have read a hundred of articles that say that all you have to do is this. Any help appreciated, thank you.
PS: I also tried the other way around, with XP as server and vista as the client, but with the same result.
