vista x86 BSOD need help
mickmeyers88
After a clean install (numerous times) i keep getting a BSOD. Doesn't show any pattern, sometimes i'll get the BSOD after having the computer on all day, or it'll happen immediately after booting up. No one application is responsible that i'm able to identify. I've disabled all hardware other then my video card, one hard drive and the audio. I've updated the BIOS, all drivers, and am running AVG virus protection and Zonealarm. Doesn't matter if i have Zonealarm and AVG running or not. I've run Memtest86 overnight on several occassions and have no error messages. Done chkdsk and checked the OS files, all okay. Also checked the motherboard for any damage or loose cables. The temperture of both processors are within normal operating range, no problem with overheating. Is there something else i can check or do?
link to minidump files: DataFileHost - Minidumps.zip
thanks, mick
OS: Vista Ultimate Sp1
CPU: Intel Core Duo E8400 3.0 GHz
MB: Gigabyte EP45-UD3P
GPU: Sapphire 100249L Radeon HD 3850 1 GB 256-bit GDDR2 PCI-e 2.0
TV Turner Card: Hauppauge WinTV HVR-1800
RAM: Corsair 4GB (2X2GB) 240-Pin DDR SDRAM 800 (PC2 6400)
Hard Drives: (2) WD Caviar Green 1 TB SATA Model: WD10EADS
Optical Drive: LG 6X Blu-Ray DVD-ROM SATA(GGC-H2OL)
Power Supply: SeaSonic OB-S12 550W ATX12v / EPS12v SLI
Case: Siverstone LC14B-MC ATX HTPC
    Gigabyte EP45-UD3P
    Radeon HD 3850 PCI-e, Hauppauge WinTV HVR-1800
    on board
    Panasonic Viera
    air
    gyration
    gyration
    cable
    The computer is a HTPC
thanks, mick
Whats the blue screen stop error code?
It starts with 0X00000???
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Hello Dinesh and thanks for taking a look.
0x00000000073 was the last error code.
mick
    Gigabyte EP45-UD3P
    on board
    Panasonic Viera
    air
    gyration
    gyration
    cable
In a BSOD, there is normally a file listed that threw the exception, normally listed in the middle of the screen. What file is throwing your OS out of whack?
eg: nVclp.dll
Additionally, check your motherboard's capacitors, see if theyre either bent outwards or darkened in color. Smell the Mobo as well, if it smells very hot or like burning oil .. well, theres your issue. If your mobo has onboard graphics, try using them after taking your video card out. Swap out your power supply for a known good one (a long shot, but Ive seen it happen). Pull out every perhiperal, addin cards, usb drives, ipods, external devices etc etc. Only have your mouse, keyboard, monitor and LAN hooked up. Take out your wireless card if you have on in. See how your system runs and if its stable, begin adding pieces back in one at a time.
Get a hold of a copy of Eurosoft PC-Check. Burn it to a CD and boot off the CD. Run every test on all of your hardware (only do smart immediate test on your HD's - Run Proc tests, video memory tests and all RAM tests, as well as the mobo tests) If everything passes, back to the drawing board. If somethings fails, ittl tell you right then and there, and even better, what specifically failed in the test and which hardware component isnt working right.
    Compaq 8710w
    Core 2 Duo T7800 26 GHz
    4 Gigs Corsair Valueselect Ram
    nVidia Quadro FX 1600m
    1920 x 1200
    500 Gig Seagate SATA drive
    DSL 1.5 mbit
