Vista x64 + X-fi Champion Noise
ZeonStar
Hey all,
Have a little problem, that while not the end of the world, though I would post about and see if maybe there is a solution out there I might not know about.
As other posts of mine mentioned, I recently made the Move not only to Vista, but x64 as well. Things have been overall fine, but something did catch my attention recently.
I've got an X-Fi Fatality Card and a front Drive Bay (actually from the Audigy ZS2 if that makes any difference at all) I started noticing last night when I am in windows, with the speakers on, but not doing anyhting, there is a constant amount of low level noise. Kind of like the sound you hear when you have speakers not playing anything turned up too loud. I can in fact turn mine up to amplify this sound. Before Vista, my speakers were dead silent even at full volume unless they were actually playing something.
Oh my speakers are Logitech Z-5500's hooked up via the 3 cable direction connection.
I get sound in everything fine. It's just this non noise I'd like to get rid of. All drivers and what not are current as far as I know.
    Q6600 B3 2.4 (OCed to 3.0 GHz)
    Abit IP35-E
    Corsair XMS2 DDR2 800 1GB x 4
    XFX Geforce GTX 260
    X-Fi Fatality w/ Audigy 2 ZS Front Bay Drive
    Dell 2407WFP & Dell 1905FP
    1920 x 1200 and 1280 x 1024
    Serial ATA 250, 300, and 160Gb
    Fotron Source 450 Watt
    Cooler Master CM 590
    DiNovo BT Laser
    diNovo BT Laser
