Crashburn162
OK so i have vista 64 i use an AIVA home cinema system which is connected through the optical cable to the pc under XP i can configure to have 5.1 speakers in vista the only way i get to see the speakers is if i disable the "front panel jack detection" otherwise i see this
When i disabled it i get this
Ok When the speakers are default i get no sound if the digital output is default i get a sound but its 2 channels only any idea how to fix it? Thanks in advance
- E8400 3.0ghz OC 3.8ghz
- MSI p7n 750i SLI Zilent
- Corsair Dominator DDR2 1066mhz
- EVGA 9800 GX2 SSC
- Realtek HD
- Samsung 959NF
- 1280x1024
- Seagate Baracuda 500gb 7200RPM
- PSU
- Corsair TX650 W
- Case
- Turbine ALu lite
- Cooling
- Zalman 9500
- Microsoft Inteli Explorer 3.0
- Microsoft wired keyboard 500 v1.0
- 10mb
