You should upgrade or use an
alternative browser .
Vista x64 install problem
I am trying to get Vista x64 installed onto a ide hard drive hooked directly to the motherboard. There are no partitions on the drive anymore and it has a mbr partition table. It is hooked up as primary master, the slave being a DVD burner. I am using a usb stick to install. The Vista installer sees the drive but has an error message: Windows is unable to install to the selected location. error: 0x80300001. Can anyone help me get through this install?
Operating System
Windows 10 Pro X64
Lenovo IdeaCenter K450
Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
16GB
NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
Samsung 27" C27F398 Curved Monitor
1920 x 1080 (HDMI)
Samsung SSD 840 EVO 250GB
Seagate ST2000NM001 2TB
Seagate ST31500341AS 1.5TB
500W
Lenovo USB
50MB Down, 10MB Up
Operating System
Windows 7 Pro X64
HP xw4400 Workstation
Intel Pentium D Dual 3.4Ghz
HP 0A68h
5GB
Realtek HD Audio
Acer KN242HYL 24" (KVMS)
1920X1080
Seagate ST3120026As 120GB SATA (boot)
Toshiba DT01ACA200 2TB SATA
Logitech via KVMS switch
Dell USB via KVMS switch
50 Down, 10 Up
Apache Web Server since 2001
If any of those solutions worked I wouldn't have posted here.
Oh I see, you already tried everything.
Good luck then.
Operating System
Windows 10 Pro X64
16GB
1920 x 1080 (HDMI)
500W
Lenovo USB
50MB Down, 10MB Up
Operating System
Windows 7 Pro X64
HP 0A68h
5GB
Realtek HD Audio
1920X1080
50 Down, 10 Up
I'm going to try making my iso myself rather than using one from the internet and see if that changes anything
Post
here and ask Peter (Ex_Brit) to send you the link to the versions of Vista you need, 32 or 64. Include your E-mail address mucked up, like
abc at xyz DOT com then edit your post and remove it as soon as you receive the link.
The ISO Peter provides has both SP1 and SP2 applied.
Pick up the Tutorial:
How to Download a Vista ISO and Create an Installation DVD or USB here:
STEP THREE
To Create Vista Installation DVD or USB Flash Drive with ISO File
During the install, when asked for the key, don't enter it. You will then be given a menu where you can chose the version you want to install.
Activate once the install is completed.
Operating System
Windows 10 Pro X64
16GB
1920 x 1080 (HDMI)
500W
Lenovo USB
50MB Down, 10MB Up
Operating System
Windows 7 Pro X64
HP 0A68h
5GB
Realtek HD Audio
1920X1080
50 Down, 10 Up
Turns out it was the iso I downloaded that was to blame. I built my own, made a usb key, and I am now able to install Vista x64
Operating System
Windows 10 Pro X64
16GB
1920 x 1080 (HDMI)
500W
Lenovo USB
50MB Down, 10MB Up
Operating System
Windows 7 Pro X64
HP 0A68h
5GB
Realtek HD Audio
1920X1080
50 Down, 10 Up
