Vista Virtual machine very laggy and slow
DoaWK1992
Hello, I've been using a Windows Vista virtual machine for a while, but a couple of months ago, it started to be very laggy and slow. I installed VMware Tools, disabled Hyper-V, and did pretty much everything I thought of, and it's still not very fast, which is weird because when I used it before, it was at least usable.
Specs:
Operating System
Windows 11 Home 64-bit
AMD Ryzen 5 Mobile 5500U 76°C
Lucienne 7nm Technology
RAM
11.0GB Dual-Channel DDR4 @ 1595MHz (22-22-22-52)
HP 88D0 (FP6)
Graphics
Generic PnP Monitor (1920x1080@60Hz)
512MB ATI AMD Radeon Graphics (HP)
    Windows 11
For an old system like mine which has a hard drive, I would suggest going into Accessories, System Tools and running the Disk Cleanup. You can do that with your system, reboot and then run whatever trash cleanup utility that comes with your SSD.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
