theonlyepi
The other day i went to go restart my computer, and everything was going as normal (bios asked for pw, vista loaded) but right before the Login screen came up for me to log in on my username (im the only user on my computer) the screen turns black, but i can still see/move my mouse.
I tried several things at this point; Ctrl+shift+esc/ctrl+alt+delete, alt+f4, alt+tab, windows key+D, windows key+E and nothing came up, still just sat at my mouse with the black screen.
Next thing i tried was safe mode. Everything seemed to be booting up as normal in safemode, but before windows loaded and went to the login screen or the desktop (i didnt get to login), it goes black again and i can only see my mouse with the same attributes as before. I tried this with all available safe modes (with cmd prompt/networking), and then i proceeded to try to boot using the last known good configuration, still no avail. I ran the memory diagnostic tool during windows boot and had it run 5 times, on the more advanced scan. nothing seemed to have gone wrong at all during that.
I just spent some time looking around for a Vista Recovery x64 cd that i could burn with one of my other computers and boot from that to see what i can do, but it seems like there's no such thing available at the moment. Unfortunatly, i cannot find my vista cd, so i'm kinda bummed out about this. If anyone has any sort of useful information, or maybe they have experienced this before, any insight on what the problem is would be more than appreciated, thanks a lot!
BTW, here's my computer specs:
AMD Athlon 64 X2 5200+
ATI x1950XT
2g PC6400 DDR2
600w power supply (might be more, i forgot)
ASUS motherboard
Oh yea, another thing to note that might be helpful, i have been using my vista system for about 8+ months now. When i first installed vista on my machine, had some serious issues, but a quick bios flash/update made things work flawlessly. I haven't had any other issues since, and i never came across any issues like this before in my years in computer repair. Thanks for the replies, hopefully i can get this machine back up and running again.
ATI x1950XT
2g PC6400 DDR2
ASUS motherboard
