JamesChatz
Hi guys,
Whenever I try to load vista it seems to be loading fine, but will stop once the icons start filling the taskbar. Sometimes I can try and run a program, but the start bar will freeze and the program will not load, however most of the time it will just freeze before this. It's taking a really long time to even get onto the desktop screen as well.
The computer loads fine in Safe Mode (which is where I am typing this from).
I have tried startup repair and it says there are no errors, tried to do a bootlog but I don't know where Windows writes the file to(although from a quick search, it appears it's not much use anyway) and I've tried system restore which completed correctly, but did not solve my problem.
I actually had this problem a little while ago, and had to reinstall my system from the Dell backup, however I've just moved into digs at Uni and of course all the stuff I would want to reinstall is at home, not to forget that it takes so long.
Spec is: Dell Studio 1555 Laptop, Dual Core T4200 Processor @ 2GHz, 4GB RAM, 512MB ATI mobility Radeon HD 4570, running Vista Home Premium 64Bit on SP2.
Can anybody shed any light on the situation? Many thanks.
- Dell Studio 1555
- Intel Dual Core T4200 Processor @ 2GHz
- 4GB
- ATI Mobility Radeon HD 4570
