Solved Vista SP2 Changed Sound Quality
I noticed a few days ago I only had SP1 installed for my x64 bit HP Pavilion Laptop. A little surprised by this, I decided I'd go ahead and install SP2.
I'm a bit of a music listener, and I've been listening to music on this laptop everyday for over 2 years now. The default settings were just right for me and worked really well with my music. However, after installing SP2, I noticed an IDT Audio icon in the taskbar. I never had that there before - it apparently had some settings for some audio quality enhancer or something. I sorta disregarded it and went straight to my tunes. I noticed off the bat the quality was different. I wouldn't say it's bad or it 'worsened' but it just sounded different than what I've been used to. I tried getting used to it but I can't get into the music as much as I used to - hit's aren't as heavy and climaxes seem dulled down or washed out.
Anyways - I tried uninstalling IDT audio only to find out that it was an actual device and that I had no sound by uninstalling it. Installing it again resulted in the same quality difference.
Is there anything I can do to get the default sound back? Would a system restore do the trick? I really don't care if I have SP1 or SP2, I just want the same sound I had before. Any tips?
Thanks!
Welcome
The facts are that SP2 has changed something that affects the quality of your music.
If you use system restore, all will be back to the way it was prior to the install of SP2. Initially, I would not go that route. I would go to search and type device manager, in device manager, uninstall the audio driver, then boot. You will have a new driver. If the quality is not imporoved, uninstall and then go to the website of the sound card and update driver from there. Its my guess that all will be good, again. Before doing anything make a system restore point, so that you can go back in case of problems.
http://www.vistax64.com/tutorials/76332-system-restore-point-create.html
Hello, for starters, you need to keep SP2, that made Vista much better , If you are just now getting your SP2, you may very well need to check your drivers for your audio . Go to the manufacture of your computer and get latest drivers, download them , then install them, make a restore pt before doing this. Also, after ensuring your drivers are up to date, in your Audio Manager, you will find when you open it up, there are sound settings that you can customize, for example, i have mine set for how i like mine to sound, you have room correction, equalizer, bunch of customized settings. But, to reiterate, keep your SP2 installed as well as any other MS updates that are needed. Post back how this works out .
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Alright well I created a restore point, uninstalled both the "High Definition Audio Device" and "IDT High Definition Audio CODEC", then restarted. Unfortunately this did not change the quality back to what it used to be. I'm fairly certain it's the IDT audio doing it's own thing by tinkering with the sound attempting to "enhance" it.
Both drivers are up to date as far as using windows "Update Driver Software" function - should I still go onto the manufacturer's site? Also, where can I find the Audio Manager? I've been looking for such a thing on the system to see if I can fix it myself.
Thanks for helpin' me out guys!
If your Icon for your Audio Manager is not showing on your taskbar next to the time, then you could go to your start button and in the search bar type Audio Manager and you should see it in results. Tell ya what, i have terrific sound from my speakers, course , i have SP2 and latest drivers for my audio installed.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Huh, two things I noticed.
The icon for the IDT audio thing is gone - not sure if that's a good thing or a bad thing. Also, my computer seems to lack an audio manager. Is it something that comes with the system as a default or is it supposed to be installed through something?
Use that restore point that you just made and lets see if you get the Audio Manager back, i think you misunderstood something, and have uninstalled wrong item. Post back please .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Actually before that restore point I also had no Audio Manager. When you mentioned it in your first post I did a search on my system to see if I had such a thing to fix the audio myself. Had nothing, I figured it was a 3rd party program or it was linked to your particular sound card. I may have, perhaps, had an audio manager before installing SP2. I vaguely recall such a thing a while ago, but I'm not certain.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Alright, did a SFC scan, here's the results:
Code:
2012-01-07 01:35:06, Info                  CSI    00000006 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:06, Info                  CSI    00000007 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:08, Info                  CSI    00000009 [SR] Verify complete
2012-01-07 01:35:09, Info                  CSI    0000000a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:09, Info                  CSI    0000000b [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:11, Info                  CSI    0000000d [SR] Verify complete
2012-01-07 01:35:12, Info                  CSI    0000000e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:12, Info                  CSI    0000000f [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:14, Info                  CSI    00000011 [SR] Verify complete
2012-01-07 01:35:14, Info                  CSI    00000012 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:14, Info                  CSI    00000013 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:17, Info                  CSI    00000015 [SR] Verify complete
2012-01-07 01:35:18, Info                  CSI    00000016 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:18, Info                  CSI    00000017 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:19, Info                  CSI    00000019 [SR] Verify complete
2012-01-07 01:35:20, Info                  CSI    0000001a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:20, Info                  CSI    0000001b [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:22, Info                  CSI    0000001d [SR] Verify complete
2012-01-07 01:35:23, Info                  CSI    0000001e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:23, Info                  CSI    0000001f [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:24, Info                  CSI    00000021 [SR] Verify complete
2012-01-07 01:35:25, Info                  CSI    00000022 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:25, Info                  CSI    00000023 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:27, Info                  CSI    00000025 [SR] Verify complete
2012-01-07 01:35:28, Info                  CSI    00000026 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:28, Info                  CSI    00000027 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:29, Info                  CSI    00000029 [SR] Verify complete
2012-01-07 01:35:30, Info                  CSI    0000002a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:30, Info                  CSI    0000002b [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:32, Info                  CSI    0000002d [SR] Verify complete
2012-01-07 01:35:33, Info                  CSI    0000002e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:33, Info                  CSI    0000002f [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:34, Info                  CSI    00000031 [SR] Verify complete
2012-01-07 01:35:35, Info                  CSI    00000032 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:35, Info                  CSI    00000033 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:37, Info                  CSI    00000035 [SR] Verify complete
2012-01-07 01:35:38, Info                  CSI    00000036 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:38, Info                  CSI    00000037 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:39, Info                  CSI    00000039 [SR] Verify complete
2012-01-07 01:35:40, Info                  CSI    0000003a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:40, Info                  CSI    0000003b [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:42, Info                  CSI    0000003d [SR] Verify complete
2012-01-07 01:35:42, Info                  CSI    0000003e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:42, Info                  CSI    0000003f [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:45, Info                  CSI    00000041 [SR] Verify complete
2012-01-07 01:35:45, Info                  CSI    00000042 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:45, Info                  CSI    00000043 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:49, Info                  CSI    00000045 [SR] Verify complete
2012-01-07 01:35:50, Info                  CSI    00000046 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:50, Info                  CSI    00000047 [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:52, Info                  CSI    00000049 [SR] Verify complete
2012-01-07 01:35:53, Info                  CSI    0000004a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:53, Info                  CSI    0000004b [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:56, Info                  CSI    0000004d [SR] Verify complete
2012-01-07 01:35:57, Info                  CSI    0000004e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:57, Info                  CSI    0000004f [SR] Beginning Verify and Repair transaction
2012-01-07 01:35:59, Info                  CSI    00000051 [SR] Verify complete
2012-01-07 01:35:59, Info                  CSI    00000052 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:35:59, Info                  CSI    00000053 [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:01, Info                  CSI    00000055 [SR] Verify complete
2012-01-07 01:36:02, Info                  CSI    00000056 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:02, Info                  CSI    00000057 [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:04, Info                  CSI    00000059 [SR] Verify complete
2012-01-07 01:36:05, Info                  CSI    0000005a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:05, Info                  CSI    0000005b [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:08, Info                  CSI    0000005d [SR] Verify complete
2012-01-07 01:36:08, Info                  CSI    0000005e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:08, Info                  CSI    0000005f [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:10, Info                  CSI    00000061 [SR] Verify complete
2012-01-07 01:36:10, Info                  CSI    00000062 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:10, Info                  CSI    00000063 [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:12, Info                  CSI    00000065 [SR] Verify complete
2012-01-07 01:36:13, Info                  CSI    00000066 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:13, Info                  CSI    00000067 [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:14, Info                  CSI    00000069 [SR] Verify complete
2012-01-07 01:36:15, Info                  CSI    0000006a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:15, Info                  CSI    0000006b [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:18, Info                  CSI    0000006d [SR] Verify complete
2012-01-07 01:36:18, Info                  CSI    0000006e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:18, Info                  CSI    0000006f [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:23, Info                  CSI    00000071 [SR] Verify complete
2012-01-07 01:36:24, Info                  CSI    00000072 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:24, Info                  CSI    00000073 [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:28, Info                  CSI    00000075 [SR] Verify complete
2012-01-07 01:36:28, Info                  CSI    00000076 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:28, Info                  CSI    00000077 [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:34, Info                  CSI    0000007b [SR] Verify complete
2012-01-07 01:36:34, Info                  CSI    0000007c [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:34, Info                  CSI    0000007d [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:40, Info                  CSI    00000080 [SR] Verify complete
2012-01-07 01:36:41, Info                  CSI    00000081 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:41, Info                  CSI    00000082 [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:46, Info                  CSI    00000086 [SR] Verify complete
2012-01-07 01:36:46, Info                  CSI    00000087 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:46, Info                  CSI    00000088 [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:50, Info                  CSI    0000008a [SR] Verify complete
2012-01-07 01:36:50, Info                  CSI    0000008b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:50, Info                  CSI    0000008c [SR] Beginning Verify and Repair transaction
2012-01-07 01:36:55, Info                  CSI    0000008e [SR] Verify complete
2012-01-07 01:36:56, Info                  CSI    0000008f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:36:56, Info                  CSI    00000090 [SR] Beginning Verify and Repair transaction
2012-01-07 01:37:03, Info                  CSI    000000b2 [SR] Verify complete
2012-01-07 01:37:04, Info                  CSI    000000b3 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:37:04, Info                  CSI    000000b4 [SR] Beginning Verify and Repair transaction
2012-01-07 01:37:08, Info                  CSI    000000b9 [SR] Verify complete
2012-01-07 01:37:09, Info                  CSI    000000ba [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:37:09, Info                  CSI    000000bb [SR] Beginning Verify and Repair transaction
2012-01-07 01:37:14, Info                  CSI    000000bd [SR] Verify complete
2012-01-07 01:37:15, Info                  CSI    000000be [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:37:15, Info                  CSI    000000bf [SR] Beginning Verify and Repair transaction
2012-01-07 01:37:19, Info                  CSI    000000c1 [SR] Verify complete
2012-01-07 01:37:19, Info                  CSI    000000c2 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:37:19, Info                  CSI    000000c3 [SR] Beginning Verify and Repair transaction
2012-01-07 01:37:24, Info                  CSI    000000c5 [SR] Verify complete
2012-01-07 01:37:24, Info                  CSI    000000c6 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:37:24, Info                  CSI    000000c7 [SR] Beginning Verify and Repair transaction
2012-01-07 01:37:31, Info                  CSI    000000c9 [SR] Verify complete
2012-01-07 01:37:32, Info                  CSI    000000ca [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:37:32, Info                  CSI    000000cb [SR] Beginning Verify and Repair transaction
2012-01-07 01:37:41, Info                  CSI    000000cd [SR] Verify complete
2012-01-07 01:37:42, Info                  CSI    000000ce [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:37:42, Info                  CSI    000000cf [SR] Beginning Verify and Repair transaction
2012-01-07 01:37:52, Info                  CSI    000000f6 [SR] Verify complete
2012-01-07 01:37:52, Info                  CSI    000000f7 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:37:52, Info                  CSI    000000f8 [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:05, Info                  CSI    000000fa [SR] Verify complete
2012-01-07 01:38:05, Info                  CSI    000000fb [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:05, Info                  CSI    000000fc [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:22, Info                  CSI    000000fe [SR] Verify complete
2012-01-07 01:38:23, Info                  CSI    000000ff [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:23, Info                  CSI    00000100 [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:30, Info                  CSI    00000102 [SR] Verify complete
2012-01-07 01:38:31, Info                  CSI    00000103 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:31, Info                  CSI    00000104 [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:36, Info                  CSI    00000106 [SR] Verify complete
2012-01-07 01:38:36, Info                  CSI    00000107 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:36, Info                  CSI    00000108 [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:39, Info                  CSI    0000010a [SR] Verify complete
2012-01-07 01:38:40, Info                  CSI    0000010b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:40, Info                  CSI    0000010c [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:42, Info                  CSI    0000010e [SR] Verify complete
2012-01-07 01:38:43, Info                  CSI    0000010f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:43, Info                  CSI    00000110 [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:46, Info                  CSI    00000112 [SR] Verify complete
2012-01-07 01:38:46, Info                  CSI    00000113 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:46, Info                  CSI    00000114 [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:49, Info                  CSI    00000116 [SR] Verify complete
2012-01-07 01:38:49, Info                  CSI    00000117 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:49, Info                  CSI    00000118 [SR] Beginning Verify and Repair transaction
2012-01-07 01:38:59, Info                  CSI    0000012b [SR] Verify complete
2012-01-07 01:38:59, Info                  CSI    0000012c [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:38:59, Info                  CSI    0000012d [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:01, Info                  CSI    0000012f [SR] Verify complete
2012-01-07 01:39:01, Info                  CSI    00000130 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:01, Info                  CSI    00000131 [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:05, Info                  CSI    00000133 [SR] Verify complete
2012-01-07 01:39:05, Info                  CSI    00000134 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:05, Info                  CSI    00000135 [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:08, Info                  CSI    00000137 [SR] Verify complete
2012-01-07 01:39:08, Info                  CSI    00000138 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:08, Info                  CSI    00000139 [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:15, Info                  CSI    0000013b [SR] Verify complete
2012-01-07 01:39:15, Info                  CSI    0000013c [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:15, Info                  CSI    0000013d [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:24, Info                  CSI    0000013f [SR] Verify complete
2012-01-07 01:39:25, Info                  CSI    00000140 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:25, Info                  CSI    00000141 [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:29, Info                  CSI    00000143 [SR] Verify complete
2012-01-07 01:39:29, Info                  CSI    00000144 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:29, Info                  CSI    00000145 [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:33, Info                  CSI    00000147 [SR] Verify complete
2012-01-07 01:39:33, Info                  CSI    00000148 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:33, Info                  CSI    00000149 [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:40, Info                  CSI    0000014b [SR] Verify complete
2012-01-07 01:39:41, Info                  CSI    0000014c [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:41, Info                  CSI    0000014d [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:46, Info                  CSI    0000014f [SR] Verify complete
2012-01-07 01:39:47, Info                  CSI    00000150 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:47, Info                  CSI    00000151 [SR] Beginning Verify and Repair transaction
2012-01-07 01:39:52, Info                  CSI    00000153 [SR] Verify complete
2012-01-07 01:39:52, Info                  CSI    00000154 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:39:52, Info                  CSI    00000155 [SR] Beginning Verify and Repair transaction
2012-01-07 01:40:03, Info                  CSI    0000016d [SR] Verify complete
2012-01-07 01:40:03, Info                  CSI    0000016e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:40:03, Info                  CSI    0000016f [SR] Beginning Verify and Repair transaction
2012-01-07 01:40:12, Info                  CSI    00000171 [SR] Verify complete
2012-01-07 01:40:12, Info                  CSI    00000172 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:40:12, Info                  CSI    00000173 [SR] Beginning Verify and Repair transaction
2012-01-07 01:40:19, Info                  CSI    00000175 [SR] Verify complete
2012-01-07 01:40:20, Info                  CSI    00000176 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:40:20, Info                  CSI    00000177 [SR] Beginning Verify and Repair transaction
2012-01-07 01:40:42, Info                  CSI    00000179 [SR] Verify complete
2012-01-07 01:40:43, Info                  CSI    0000017a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:40:43, Info                  CSI    0000017b [SR] Beginning Verify and Repair transaction
2012-01-07 01:40:56, Info                  CSI    0000017d [SR] Verify complete
2012-01-07 01:40:56, Info                  CSI    0000017e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:40:56, Info                  CSI    0000017f [SR] Beginning Verify and Repair transaction
2012-01-07 01:41:08, Info                  CSI    00000181 [SR] Verify complete
2012-01-07 01:41:09, Info                  CSI    00000182 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:41:09, Info                  CSI    00000183 [SR] Beginning Verify and Repair transaction
2012-01-07 01:41:15, Info                  CSI    00000185 [SR] Verify complete
2012-01-07 01:41:16, Info                  CSI    00000186 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:41:16, Info                  CSI    00000187 [SR] Beginning Verify and Repair transaction
2012-01-07 01:41:23, Info                  CSI    00000189 [SR] Verify complete
2012-01-07 01:41:24, Info                  CSI    0000018a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:41:24, Info                  CSI    0000018b [SR] Beginning Verify and Repair transaction
2012-01-07 01:41:29, Info                  CSI    0000018d [SR] Verify complete
2012-01-07 01:41:30, Info                  CSI    0000018e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:41:30, Info                  CSI    0000018f [SR] Beginning Verify and Repair transaction
2012-01-07 01:41:36, Info                  CSI    00000193 [SR] Verify complete
2012-01-07 01:41:37, Info                  CSI    00000194 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:41:37, Info                  CSI    00000195 [SR] Beginning Verify and Repair transaction
2012-01-07 01:41:41, Info                  CSI    00000197 [SR] Verify complete
2012-01-07 01:41:41, Info                  CSI    00000198 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:41:41, Info                  CSI    00000199 [SR] Beginning Verify and Repair transaction
2012-01-07 01:42:00, Info                  CSI    0000019b [SR] Verify complete
2012-01-07 01:42:01, Info                  CSI    0000019c [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:42:01, Info                  CSI    0000019d [SR] Beginning Verify and Repair transaction
2012-01-07 01:42:07, Info                  CSI    0000019f [SR] Verify complete
2012-01-07 01:42:07, Info                  CSI    000001a0 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:42:07, Info                  CSI    000001a1 [SR] Beginning Verify and Repair transaction
2012-01-07 01:42:14, Info                  CSI    000001a3 [SR] Verify complete
2012-01-07 01:42:15, Info                  CSI    000001a4 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:42:15, Info                  CSI    000001a5 [SR] Beginning Verify and Repair transaction
2012-01-07 01:42:29, Info                  CSI    000001a7 [SR] Verify complete
2012-01-07 01:42:29, Info                  CSI    000001a8 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:42:29, Info                  CSI    000001a9 [SR] Beginning Verify and Repair transaction
2012-01-07 01:42:30, Info                  CSI    000001ab [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-01-07 01:42:34, Info                  CSI    000001ad [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-01-07 01:42:34, Info                  CSI    000001ae [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2012-01-07 01:42:35, Info                  CSI    000001b0 [SR] Verify complete
2012-01-07 01:42:36, Info                  CSI    000001b1 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:42:36, Info                  CSI    000001b2 [SR] Beginning Verify and Repair transaction
2012-01-07 01:42:42, Info                  CSI    000001b4 [SR] Verify complete
2012-01-07 01:42:43, Info                  CSI    000001b5 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:42:43, Info                  CSI    000001b6 [SR] Beginning Verify and Repair transaction
2012-01-07 01:42:51, Info                  CSI    000001b8 [SR] Verify complete
2012-01-07 01:42:52, Info                  CSI    000001b9 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:42:52, Info                  CSI    000001ba [SR] Beginning Verify and Repair transaction
2012-01-07 01:43:02, Info                  CSI    000001bd [SR] Verify complete
2012-01-07 01:43:03, Info                  CSI    000001be [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:43:03, Info                  CSI    000001bf [SR] Beginning Verify and Repair transaction
2012-01-07 01:43:10, Info                  CSI    000001c1 [SR] Verify complete
2012-01-07 01:43:11, Info                  CSI    000001c2 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:43:11, Info                  CSI    000001c3 [SR] Beginning Verify and Repair transaction
2012-01-07 01:43:16, Info                  CSI    000001c5 [SR] Verify complete
2012-01-07 01:43:17, Info                  CSI    000001c6 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:43:17, Info                  CSI    000001c7 [SR] Beginning Verify and Repair transaction
2012-01-07 01:43:22, Info                  CSI    000001ca [SR] Verify complete
2012-01-07 01:43:22, Info                  CSI    000001cb [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:43:22, Info                  CSI    000001cc [SR] Beginning Verify and Repair transaction
2012-01-07 01:43:29, Info                  CSI    000001cf [SR] Verify complete
2012-01-07 01:43:30, Info                  CSI    000001d0 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:43:30, Info                  CSI    000001d1 [SR] Beginning Verify and Repair transaction
2012-01-07 01:43:36, Info                  CSI    000001db [SR] Verify complete
2012-01-07 01:43:37, Info                  CSI    000001dc [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:43:37, Info                  CSI    000001dd [SR] Beginning Verify and Repair transaction
2012-01-07 01:43:44, Info                  CSI    000001fe [SR] Verify complete
2012-01-07 01:43:44, Info                  CSI    000001ff [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:43:44, Info                  CSI    00000200 [SR] Beginning Verify and Repair transaction
2012-01-07 01:43:53, Info                  CSI    00000202 [SR] Verify complete
2012-01-07 01:43:53, Info                  CSI    00000203 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:43:53, Info                  CSI    00000204 [SR] Beginning Verify and Repair transaction
2012-01-07 01:44:04, Info                  CSI    00000206 [SR] Verify complete
2012-01-07 01:44:04, Info                  CSI    00000207 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:44:04, Info                  CSI    00000208 [SR] Beginning Verify and Repair transaction
2012-01-07 01:44:11, Info                  CSI    0000020a [SR] Verify complete
2012-01-07 01:44:11, Info                  CSI    0000020b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:44:11, Info                  CSI    0000020c [SR] Beginning Verify and Repair transaction
2012-01-07 01:44:14, Info                  CSI    0000020e [SR] Verify complete
2012-01-07 01:44:14, Info                  CSI    0000020f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:44:14, Info                  CSI    00000210 [SR] Beginning Verify and Repair transaction
2012-01-07 01:44:20, Info                  CSI    00000212 [SR] Verify complete
2012-01-07 01:44:21, Info                  CSI    00000213 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:44:21, Info                  CSI    00000214 [SR] Beginning Verify and Repair transaction
2012-01-07 01:44:31, Info                  CSI    00000216 [SR] Verify complete
2012-01-07 01:44:32, Info                  CSI    00000217 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:44:32, Info                  CSI    00000218 [SR] Beginning Verify and Repair transaction
2012-01-07 01:44:42, Info                  CSI    0000021a [SR] Verify complete
2012-01-07 01:44:43, Info                  CSI    0000021b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:44:43, Info                  CSI    0000021c [SR] Beginning Verify and Repair transaction
2012-01-07 01:44:48, Info                  CSI    0000021e [SR] Verify complete
2012-01-07 01:44:48, Info                  CSI    0000021f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:44:48, Info                  CSI    00000220 [SR] Beginning Verify and Repair transaction
2012-01-07 01:45:02, Info                  CSI    00000222 [SR] Verify complete
2012-01-07 01:45:03, Info                  CSI    00000223 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:45:03, Info                  CSI    00000224 [SR] Beginning Verify and Repair transaction
2012-01-07 01:45:08, Info                  CSI    00000226 [SR] Verify complete
2012-01-07 01:45:09, Info                  CSI    00000227 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:45:09, Info                  CSI    00000228 [SR] Beginning Verify and Repair transaction
2012-01-07 01:45:11, Info                  CSI    0000022a [SR] Verify complete
2012-01-07 01:45:11, Info                  CSI    0000022b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:45:11, Info                  CSI    0000022c [SR] Beginning Verify and Repair transaction
2012-01-07 01:45:17, Info                  CSI    0000022e [SR] Verify complete
2012-01-07 01:45:17, Info                  CSI    0000022f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:45:17, Info                  CSI    00000230 [SR] Beginning Verify and Repair transaction
2012-01-07 01:45:29, Info                  CSI    0000023e [SR] Verify complete
2012-01-07 01:45:30, Info                  CSI    0000023f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:45:30, Info                  CSI    00000240 [SR] Beginning Verify and Repair transaction
2012-01-07 01:45:37, Info                  CSI    00000242 [SR] Verify complete
2012-01-07 01:45:37, Info                  CSI    00000243 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:45:37, Info                  CSI    00000244 [SR] Beginning Verify and Repair transaction
2012-01-07 01:45:44, Info                  CSI    00000246 [SR] Verify complete
2012-01-07 01:45:45, Info                  CSI    00000247 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:45:45, Info                  CSI    00000248 [SR] Beginning Verify and Repair transaction
2012-01-07 01:45:52, Info                  CSI    0000024a [SR] Verify complete
2012-01-07 01:45:52, Info                  CSI    0000024b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:45:52, Info                  CSI    0000024c [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:00, Info                  CSI    0000024e [SR] Verify complete
2012-01-07 01:46:01, Info                  CSI    0000024f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:01, Info                  CSI    00000250 [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:10, Info                  CSI    00000252 [SR] Verify complete
2012-01-07 01:46:11, Info                  CSI    00000253 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:11, Info                  CSI    00000254 [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:12, Info                  CSI    00000256 [SR] Verify complete
2012-01-07 01:46:12, Info                  CSI    00000257 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:12, Info                  CSI    00000258 [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:16, Info                  CSI    0000025b [SR] Verify complete
2012-01-07 01:46:17, Info                  CSI    0000025c [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:17, Info                  CSI    0000025d [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:25, Info                  CSI    00000264 [SR] Verify complete
2012-01-07 01:46:25, Info                  CSI    00000265 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:25, Info                  CSI    00000266 [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:30, Info                  CSI    00000268 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-01-07 01:46:36, Info                  CSI    0000026a [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-01-07 01:46:36, Info                  CSI    0000026b [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2012-01-07 01:46:39, Info                  CSI    0000026f [SR] Verify complete
2012-01-07 01:46:40, Info                  CSI    00000270 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:40, Info                  CSI    00000271 [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:49, Info                  CSI    00000286 [SR] Verify complete
2012-01-07 01:46:50, Info                  CSI    00000287 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:50, Info                  CSI    00000288 [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:53, Info                  CSI    0000028a [SR] Verify complete
2012-01-07 01:46:54, Info                  CSI    0000028b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:54, Info                  CSI    0000028c [SR] Beginning Verify and Repair transaction
2012-01-07 01:46:57, Info                  CSI    0000028e [SR] Verify complete
2012-01-07 01:46:57, Info                  CSI    0000028f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:46:57, Info                  CSI    00000290 [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:04, Info                  CSI    00000292 [SR] Verify complete
2012-01-07 01:47:04, Info                  CSI    00000293 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:04, Info                  CSI    00000294 [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:09, Info                  CSI    00000298 [SR] Verify complete
2012-01-07 01:47:09, Info                  CSI    00000299 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:09, Info                  CSI    0000029a [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:14, Info                  CSI    0000029d [SR] Verify complete
2012-01-07 01:47:15, Info                  CSI    0000029e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:15, Info                  CSI    0000029f [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:19, Info                  CSI    000002a1 [SR] Verify complete
2012-01-07 01:47:19, Info                  CSI    000002a2 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:19, Info                  CSI    000002a3 [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:26, Info                  CSI    000002c8 [SR] Verify complete
2012-01-07 01:47:27, Info                  CSI    000002c9 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:27, Info                  CSI    000002ca [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:30, Info                  CSI    000002cc [SR] Verify complete
2012-01-07 01:47:30, Info                  CSI    000002cd [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:30, Info                  CSI    000002ce [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:35, Info                  CSI    000002d0 [SR] Verify complete
2012-01-07 01:47:36, Info                  CSI    000002d1 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:36, Info                  CSI    000002d2 [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:40, Info                  CSI    000002d4 [SR] Verify complete
2012-01-07 01:47:41, Info                  CSI    000002d5 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:41, Info                  CSI    000002d6 [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:45, Info                  CSI    000002d8 [SR] Verify complete
2012-01-07 01:47:45, Info                  CSI    000002d9 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:45, Info                  CSI    000002da [SR] Beginning Verify and Repair transaction
2012-01-07 01:47:52, Info                  CSI    000002ee [SR] Verify complete
2012-01-07 01:47:53, Info                  CSI    000002ef [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:47:53, Info                  CSI    000002f0 [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:08, Info                  CSI    000002f2 [SR] Verify complete
2012-01-07 01:48:08, Info                  CSI    000002f3 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:08, Info                  CSI    000002f4 [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:18, Info                  CSI    00000302 [SR] Verify complete
2012-01-07 01:48:18, Info                  CSI    00000303 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:18, Info                  CSI    00000304 [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:22, Info                  CSI    00000306 [SR] Verify complete
2012-01-07 01:48:22, Info                  CSI    00000307 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:22, Info                  CSI    00000308 [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:26, Info                  CSI    0000030a [SR] Verify complete
2012-01-07 01:48:26, Info                  CSI    0000030b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:26, Info                  CSI    0000030c [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:36, Info                  CSI    0000030f [SR] Verify complete
2012-01-07 01:48:36, Info                  CSI    00000310 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:36, Info                  CSI    00000311 [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:41, Info                  CSI    00000313 [SR] Verify complete
2012-01-07 01:48:41, Info                  CSI    00000314 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:41, Info                  CSI    00000315 [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:44, Info                  CSI    00000317 [SR] Verify complete
2012-01-07 01:48:44, Info                  CSI    00000318 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:44, Info                  CSI    00000319 [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:51, Info                  CSI    0000031b [SR] Verify complete
2012-01-07 01:48:52, Info                  CSI    0000031c [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:52, Info                  CSI    0000031d [SR] Beginning Verify and Repair transaction
2012-01-07 01:48:57, Info                  CSI    0000031f [SR] Verify complete
2012-01-07 01:48:57, Info                  CSI    00000320 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:48:57, Info                  CSI    00000321 [SR] Beginning Verify and Repair transaction
2012-01-07 01:49:04, Info                  CSI    00000325 [SR] Verify complete
2012-01-07 01:49:04, Info                  CSI    00000326 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:49:04, Info                  CSI    00000327 [SR] Beginning Verify and Repair transaction
2012-01-07 01:49:13, Info                  CSI    00000341 [SR] Verify complete
2012-01-07 01:49:14, Info                  CSI    00000342 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:49:14, Info                  CSI    00000343 [SR] Beginning Verify and Repair transaction
2012-01-07 01:49:20, Info                  CSI    00000345 [SR] Verify complete
2012-01-07 01:49:21, Info                  CSI    00000346 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:49:21, Info                  CSI    00000347 [SR] Beginning Verify and Repair transaction
2012-01-07 01:49:40, Info                  CSI    00000349 [SR] Verify complete
2012-01-07 01:49:40, Info                  CSI    0000034a [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:49:40, Info                  CSI    0000034b [SR] Beginning Verify and Repair transaction
2012-01-07 01:49:45, Info                  CSI    0000034d [SR] Verify complete
2012-01-07 01:49:46, Info                  CSI    0000034e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:49:46, Info                  CSI    0000034f [SR] Beginning Verify and Repair transaction
2012-01-07 01:49:54, Info                  CSI    00000351 [SR] Verify complete
2012-01-07 01:49:54, Info                  CSI    00000352 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:49:54, Info                  CSI    00000353 [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:00, Info                  CSI    00000355 [SR] Verify complete
2012-01-07 01:50:00, Info                  CSI    00000356 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:00, Info                  CSI    00000357 [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:04, Info                  CSI    0000035a [SR] Verify complete
2012-01-07 01:50:05, Info                  CSI    0000035b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:05, Info                  CSI    0000035c [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:19, Info                  CSI    0000035e [SR] Verify complete
2012-01-07 01:50:19, Info                  CSI    0000035f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:19, Info                  CSI    00000360 [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:26, Info                  CSI    00000362 [SR] Verify complete
2012-01-07 01:50:26, Info                  CSI    00000363 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:26, Info                  CSI    00000364 [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:32, Info                  CSI    00000366 [SR] Verify complete
2012-01-07 01:50:33, Info                  CSI    00000367 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:33, Info                  CSI    00000368 [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:38, Info                  CSI    0000036a [SR] Verify complete
2012-01-07 01:50:38, Info                  CSI    0000036b [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:38, Info                  CSI    0000036c [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:43, Info                  CSI    0000036e [SR] Verify complete
2012-01-07 01:50:43, Info                  CSI    0000036f [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:43, Info                  CSI    00000370 [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:49, Info                  CSI    00000373 [SR] Verify complete
2012-01-07 01:50:49, Info                  CSI    00000374 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:49, Info                  CSI    00000375 [SR] Beginning Verify and Repair transaction
2012-01-07 01:50:55, Info                  CSI    00000377 [SR] Verify complete
2012-01-07 01:50:55, Info                  CSI    00000378 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:50:55, Info                  CSI    00000379 [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:01, Info                  CSI    0000037c [SR] Verify complete
2012-01-07 01:51:02, Info                  CSI    0000037d [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:51:02, Info                  CSI    0000037e [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:09, Info                  CSI    00000384 [SR] Verify complete
2012-01-07 01:51:10, Info                  CSI    00000385 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:51:10, Info                  CSI    00000386 [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:16, Info                  CSI    00000388 [SR] Verify complete
2012-01-07 01:51:17, Info                  CSI    00000389 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:51:17, Info                  CSI    0000038a [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:24, Info                  CSI    0000038d [SR] Verify complete
2012-01-07 01:51:24, Info                  CSI    0000038e [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:51:24, Info                  CSI    0000038f [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:33, Info                  CSI    00000391 [SR] Verify complete
2012-01-07 01:51:34, Info                  CSI    00000392 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:51:34, Info                  CSI    00000393 [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:41, Info                  CSI    00000395 [SR] Verify complete
2012-01-07 01:51:42, Info                  CSI    00000396 [SR] Verifying 100 (0x0000000000000064) components
2012-01-07 01:51:42, Info                  CSI    00000397 [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:50, Info                  CSI    00000399 [SR] Verify complete
2012-01-07 01:51:50, Info                  CSI    0000039a [SR] Verifying 36 (0x0000000000000024) components
2012-01-07 01:51:50, Info                  CSI    0000039b [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:52, Info                  CSI    0000039d [SR] Verify complete
2012-01-07 01:51:52, Info                  CSI    0000039e [SR] Repairing 2 components
2012-01-07 01:51:52, Info                  CSI    0000039f [SR] Beginning Verify and Repair transaction
2012-01-07 01:51:53, Info                  CSI    000003a1 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-01-07 01:51:53, Info                  CSI    000003a3 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-01-07 01:51:53, Info                  CSI    000003a5 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-01-07 01:51:53, Info                  CSI    000003a6 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2012-01-07 01:51:53, Info                  CSI    000003a8 [SR] Cannot repair member file [l:24{12}]"settings.ini" of Microsoft-Windows-Sidebar, Version = 6.0.6002.18005, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2012-01-07 01:51:53, Info                  CSI    000003a9 [SR] This component was referenced by [l:162{81}]"Package_17_for_KB948465~31bf3856ad364e35~amd64~~6.0.1.18005.948465-60_neutral_GDR"
2012-01-07 01:51:53, Info                  CSI    000003ab [SR] Repair complete
2012-01-07 01:51:53, Info                  CSI    000003ac [SR] Committing transaction
2012-01-07 01:51:53, Info                  CSI    000003b0 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction  have been successfully repaired
I think everyone has that sidebar error, last i checked on that , Microsoft has not fixed it yet. You may have no other option except to go back to a point where your sound was working, then install updates one by one to see which one has caused this issue. See how that works for you.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Just as pointer here: -
I would not install any Windows recommended sound drivers for your system, they are not fully compatable with the hardware. I know from experience.
If this is your problem & you can get it back working, without a full recovery to day one, you have done well. I did not manage to do it!
Good luck & hope yu manage to recover your ssytem.
Paul H.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Alright thanks for the help guys! I'll look into a system recovery back to before the SP2 update.
I find it strange though that my windows updater never mentioned SP2 - I was kinda surprised I didn't have it. What are the best advantages to SP2 over SP1?
Also, any idea how I can get audio manager back? I'm not even sure if I had it BEFORE installing SP2. If I can tweak my audio settings then I won't needa resort to a recovery. Maybe there's a 3rd party program that I could try?
Thanks!
SP2 compiled bug fixes and when installed , saved alot of space as quite a few of the SP1 were removed , i had a friend that wound up with almost 2 gigs of space after installing the SP2, he also mentioned that his Vista performed much better, also, it should be noted that a person really should always use latest applicable updates that are available for ones computer to provide security patches and enhance the performance of the System files.
You might want to use Speccy , a free program , gives you your hardware specs plus software driver info. Speccy - System Information - Free Download
Also, to keep yourself updated , once you have time , use this , also free : Free Computer Security - Personal Software Inspector (PSI) - Secunia
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
As I said earlier, if a Windows update driver for the sound system has been installed, like I did, then I could not get tit back to fully functional & had to restore. The sound device manager is part of the drivers.
Only update via the HP update facility for the Sound system. OK?
    40 Meg
Thanks for the help guys!
Before I do a system restore, my last chance to gain my sound back is to be able to get a 3rd party program similar to Audio Manager. Does anyone know of such a program that I could use to possibly tweak my sound back?
OK,
Lets start with this: -
What is the specific model number for your laptop & I will look for the 64Bit system "Audio manager" & correct drivers.
    40 Meg
    40 Meg
Good news!
I was looking through the drivers and wasn't finding much toward an audio manager. I googled "HP audio manager" and noticed a lot of people have a Realtek HD Audio manager. I decided to take a look on a thread on it and found out it can be accessed through control panel > sound and hardware. I went there an noticed that same IDT Audio icon that I originally mentioned in my first post. This time I decided upon actually checking it out (d'oh) instead of ignoring it and blaming it responsible for my poor audio. I realized this was my audio manager (although it was called audio panel for me), and it had some crappy preset that it had in effect constantly. A few minutes of fumbling with the settings and I have much sexier sound quality now.
So it seems that SP2 installed this audio panel that immediately put its garbage mono 8kbps 2khz preset that haunted me for days. Thanks to you guys, I managed to remedy that.
Thanks again! Audio sounds beautiful once more. I'll definitely be hanging around this forum more.
