Vista SP1 Uninstall problem.
SilverWS602
Vista Pro
So this is the first issue I've really had with this.
I try to uninstall the current SP1 to install the new refresh and this is what happens.
All goes well until stage 3. Stage 3 gets to 74-75% and "hangs". When I say hangs... it does progress... SLOOOOOWLLLLYYY. Eventually its gets to about 85% then jumps to 100% and eventually says "uninstall has failed" and reverts changes.
It's 11:30pm right now. I started the uninstall at ~6:15pm. Between it going slowly and then reverting the changes, thats how long it took. Tried this twice so far, both with the same result. I previously uninstalled a different version of the SP, no issues.
Ideas?
I believe that if you have the original rc you have to uninstall it for refresh 1, but if you are going from refresh 1 to refresh 2 you do not uninstall. Could be wrong tho.
    i7 940 @ 4GHz (193 x 21) w/CNPS9900LED
    Asus P6T Deluxe (BIOS 1604)
    6GB (3x2GB) Corsair DDR3-1600 @ 8-8-8-21-1N
    Tri-Fire 4870x2 + 4870 1GB
    Azun Prelude 7.1 + Inspire T6200 5.1
    Dell 3008WFP
    2560 x 1600
    300GB WD VelicoRaptor
    SilverStone DA 1200
    CM HAF 932
    3x230mm 1x140mm 1x120mm
    MX Revolution
    G15 Gaming KB
Yes, I have build 6001. Hope that I can uninstall it OK. I can see this forum being bombarded with such messages..I will probably be one of them, lol.
    Dual Core E7200
    Asus P5K
    4GB DDR2 800 SDRAM
    GForce 8600GTS 512mb
    Auzentech XFi Prelude 7.1 on Onkyo605 Rxer
    20" Samsung SyncMaster 206BW
    Sky UK
I was thinking you could go ahead and update with refresh 2 and then try and uninstall if need be. Since you have used restore it is a moot point anyway.:)
    Dell 3008WFP
    2560 x 1600
    SilverStone DA 1200
    CM HAF 932
    MX Revolution
    G15 Gaming KB
