Vista Sound Schemes
I have an authentic Vista sound pack for my Windows 10 but I don't know what sounds go to where. Since Asterisk doesn't use Asterisk.wav it uses something like Balloon.wav instead I can't figure out what the original Vista had. Can someone either list or screen shot what sounds go to what? Thanks.
I know this isn't exactly what you wanted but thought I'd post it anyhow. Most of the things on the lists are self explanatory. If there's a couple you want to know the sound association, let me know.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
I need to know what the following are
Asterisk
Critical Stop
Default Beep
Exclamation
I know it's a PITA but if you could list me off all the ones at least under the Windows section I'd be eternally grateful.
Thanks
Asterisk- Windows error.wav
Critical stop- Windows critical stop.wav
Default Beep- Windows ding.wav
Exclamation- Windows Exclamation.wav
As you notice, the .wav files for a couple of the sounds have the same sound name in their name. (that's a real sentence isn't it? :D)
To my knowledge, I've never changed the default sounds. Let me know if there's anything else I can help you with.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
There's the New Fax Notification and New Mail Notification which both use the Windows Notify.wav.
There's a System Notification which uses the Windows Balloon.wav.
There's also a Windows Explorer Notification Bar which uses the Windows Information Bar.wav file.
I didn't see any others.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
