Vista runs slow when not at home
jeliac
For some reason when I run my computer from work it runs extremely slow. The the only difference I can see that could be affecting it is that at home I use wifi to connect to the internet. I'm always connected to the internet. At work there is no wifi, and not connected to the internet. Could it be trying to do something online, but since it cant connect, keep trying and trying and trying slowing everything down?
To fix it I have to restart it. This seems to do the job, however I'd rather not have to do this every time.
At home this never happens. I never have to restart it to get it to move faster. And this happens EVERY TIME at work.
Any ideas?
Thanks,
alec
Yes, if you are remotely logging in. However, have you configured the software and router properly?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
I'm not trying to log into my works wifi. My system itself is just running slower when I'm NOT linked to my wifi at home (when I run programs that have nothing to do with the internet). When it's not connected to the internet I'm having this problem with my overall system.
Fill in your hardware specs and use HWInfo32:
HWiNFO32 Download
What antivirus are you using? What runs at startup in msconfig? What apps have you installed?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
i think it is just scanning around for access points while you are disconnected.
press the Windows button on your keyboard and at the same time press x. click 'Turn wireless off'. post back.
also have a look at what Frostmourne says as well.
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
