vista problems
jagdryan
os windows vista home premium, model dx4720-03,processor pentium(R) Dual-core cpu E5200 @ 2.50ghz,memory 4094, directX 10,grafic card geforce 9500 gt,
the problem i am having is vista is crashing forceing a hard reboot it some times does a bsod but all the other times it forces hard reboot. it last like 5mins to 1 hour when on some times longer but the forced hardreboot. i have use some reg cleaners still haveing some problem. my computer is not over heating i have took the door and ran the computer tell it stop and see if any thing was hot enought to burn witch nothin. i have reinstall vista like 3 times and i am haveing the same problem. i have almost replace all parts but the mother board its self and hard drive. i am went to geak squard and they said there was nothin they can do. how do i fix this problem
My daughters computer did that a couple of months ago. Went into an endless boot cycle. Unfortunately it was the HDD going bad and subsequently caused problems with the rest of the hardware. Ended up making "D" new "C" drive but also had to add a addin Sata card to connect drives to as MB HDD connections were now inop, having to do clean install and everything has been fine since.
Believe me I am one of those that will try almost anything to avoid having to do a clean install, but sometimes no choice.
    Self Build
    Intel Core 2 Quad Q6600 Kentsfield 2.4 Ghz LGA 775 Quad
    Foxconn P45A-S LGA 775 Intel P45 ATX
    OCZ2VU80016GQ 16GB (4x4GB) DDR2 800Mhz Vista Dual Channel
    2- Sapphire 10022SL Radeon HD 3850 PCI-e in Crossfire mode
    Acer H213H 21.5" Widescreen Full HD 1080P LCD
    2- Seagate ST3160023AS HD 500GB 2- Seagate ST31000333AS HD 1TB 1- Seagate ST310005FJA105-RK Freeagent Desk 1TB
    Enermax EG701AX 600W Switching Power Supply
    Lian Li PC-70 Ext/ATX
    Artic Cooling Freezer 7 Pro for Intel CPU
    Intellimouse Optical
    MS Keyboard Pro
    3766.5Kbits 470.8KBytes
    2- Incessa IN-811 removable drive bays and 8- removable drive bay caddies.
i have done a clean install whiped every thing from computer and reinstall went to mother board site and got drivers and vidoe drivers and all but its still forceing hard reboot while in vista sitting there in notpad typing it just stops working like playing a game it stop you do any thing on it after like 30min or so it stop working and its not right i been trying every thing kinda so i am asking if there is any that can be or is it i just need to buy a new hard drive and then try clean install
Do not worry if you cannot see the BSOD, just upload the contents of the:
"C:\Windows\Minidump"
folder in zip format and we will take a look at your BSOD.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
yea hmm it says it (((Windows cannot find C:\Windows\Minidump . Cheak spelling and try again))))) so there no way i can upload the contents of a folder that its saying its not there at all so that link was not helpfull at all
If you are trying to search for the folder, or use Command Prompt, just manually direct Windows Explorer to the location, copy the folder onto your desktop, then zip it up and upload.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
i have tryed theres nothin there at all. you know how you have the search bar when ontop of the folder i copy and paste it there and it says its not there i tryed going to it i do not see it any were
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
I have analysed your Minidump:
SYSTEM_SERVICE_EXCEPTION
STOP: 0x0000003b
First, try to update your graphics card driver, your chipset driver if you can, and as many other drivers as possible. Run Memtest86+ or another memory testing tool that came with your computer. Make sure all windows updates and service packs are installed. Download and run the free Malwarebytes Anti-Malware.
You also have quite a few old drivers that need to be updated:
2006:
mdmxsdk.sys
xaudio64.sys
secdrv.SYS
peauth.sys
Null.sys
swenum.sys
2007:
nvraid.sys
PxHlpa64.sys
nvsmu.sys
nvmfdx64.sys
int15_64.sys
Can you also upload the results in .txt format of this tool: http://www.vistax64.com/tutorials/176785-vistaforums-sysinfo-tool.html
Thanks,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Richard;
Can you do me a favor and look at the attached Code. docs and attempt to assertain why one of the svcs host (local) would be causing me intermittant problems. This Am was on the computer with Internet access. Got done, went to bed. When I got up later, activated the computer from sleep, not only was the CPU showing continous 26% to 49% usage but it was now disconnected from the internet and windows diagnostics could/would not identify the problem. I could not manually connect and was limited as to what I could do. Applications/processes showed the local service to be utilizing 25% of CPU @ the time. Had something to do with remote desktop but have been unable to determine if it is because of daughters networked computer or outside sorce. Ended up doing a restart to not only stop the process but also reconnect to the internet.
Because of your system tools link, thanks, was I able to provide the attached file. Also there is a minidump of the actual svc process.
Unable to upload zipped file of minidump.
    Self Build
    MS Keyboard Pro
Richard;
Let me upload later as the only zipping/unzipping programs I have are Zipeg and RAR and it won't let me upload them. Will try to find a free zip program.
Use the free 7-Zip and encode in .zip format NOT .7z. If this is going to turn into a medium-long multi reply problem, can you please create a new thread. This will also have the benefit of your thread appearing for the whole forum to read. If you do create a new thread, send me a PM with the link.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Richard, Sorry that I missed your reply but was trying to get the DMP file now zipped uploaded but for whatever reson it won't upload. It's only 24K KB and zipped so I'm at a loss. Will take suggestions as it is the mini dump file from the svc host process that I believe is causing the problem.
    Self Build
    MS Keyboard Pro
Make sure you copy the Minidump to your Desktop first THEN zip it up. There are problems uploading files from System directories etc.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Also, if you really cannot upload the zip file, copy the Minidump to your desktop, rename it to .txt and try to upload that. Do nothing else to the Minidump and make no change whatsoever to the file.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Tried twice to upload it, went thru the process but came back as failed to upload. Have changed to txt, but is now over 82MB and was disconnected from the website while attempting to upload. I attempted evan tho figured to be oversize.
Let me take a break and drop back and punt.
    Self Build
    MS Keyboard Pro
