Vista problems
skim1994
Hi I bought a computer from Velocity Micro. It has a Geforce 9500GT graphics card, a 500gb Hitachi hardrive, and 2 gig memory. It runs about 2.4 ghz. However, I have been having major issues with this computer. I get constant bsods. So far I have reinstalled the driver, replaced a bad memory stick with a replacement, and updated everything I basically have on my computer, including the mouse. However, I have done many tests which revealed that there is nothing wrong with the hardware. There was a problem with my belkin wireless card so i replaced it with a Ralink wireless LAN card. However, i am still getting bsods and the techs at velocity say that there might be a issue with this card too. Now i am just speculating but its too weird to have 2 internet cards which malfunction, one of them which is only a few months old. Can someone just tell me if it were the two so called "malfunctioning" cards or it might be something else.
skim1994,
Is there any Error Message/Code you get? Test your computer in safe mode and let us know.
Post your event viewer report.
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    19" Viewsonic and Sony 26" S Series TV
    1920x1080
    Sata (1 TB) and IDE (350GB)
    Optical (Wireless)
    Multimedia (Wireless)
    2MB
He means the error information displayed by the BSOD.
Usually this problem is caused by DRAM, I assume you have run the memory test. Another thing might be the PSU.
    E8400
    asus p5ql-e
    ocz pc 1066 2x2gb
    asus eah3650 silent
    Edirol UA-25
    Gateway FPD2185W
    1680 x 1050
    750g samsung
    Zalman ZM460B 460W
    Lian Li A05 + 2 x Sythe S-FLEX SFF21D 120mm case fan
    Coolermaster Hyper Z600 fanless CPU cooler
    Microsoft Laser Mouse 6000
    Merc Stealth
    DSL
Yea I ran the memory test and also something called Hot CPU tester Pro 4. Both came up fine (although i did have to replace one bad memory stick). Also, did you mean the word information by the BSOD or the number?
