vista problems
slayr78
i have been having a few problems with my new vista computer its a hp txz 2500z with vista buisness and im the administrater acount if that will help
first prob is when i try to log off or shut or restart down the computer it hangs in the shutingdown or loging off screen and i have to use the power button to turn it off
other prob is the taskmanager wont show up. i see its icon in the bottom right bar (green gridlike box) it jus wont show up on the screen
last some programs wont open like itunes or the conect to a network and network setings and sometimes windows defender i think they might run in the background but i cant get taskmanager running
    Core Duo 2 E6700
    ASUS P5W DH Deluxe
    4g-Corsair XMS2 6400
    ATI 4870x2
    2 Maxtor Essential SATA2 drives Raid 0 Pioneer 212D SATA DVD-R/W
marry i dont think u get what i mena. when i try to shut down restart or log off the vomputer hangs at the shuting down screen. in order to turn off my computer i have to hold the powerbutton. i dont want to change the setings for the powerbutton
I know that, I wasnt going for that I wanted you to check and see if you noticed any abonormalites under those steps. If you do the power buttons advance settings, it could be a way to figuring out the problem. Sorry I didnt clarify, but I do understand what your problem is.
This person went to task manager and turned off DWM.exe....Anyways they have a unique way, which is different then every other forum which pretty much says its some program you have installed.
http://www.techspot.com/vb/topic108939.html
heres other people with same problem, main solution in common is a program you have installed.
http://www.msfn.org/board/VISTA-won-t-shutdown-t113154.html
windows vista general Why Won't Vista Shut Down?
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=1742944&SiteID=17&pageid=1
Sorry if it was an inconvience earlier.
    Intel(R) Pentium(R) Dual CPU
    Phoenix ROM BIOS PLUS Version 1.10 A11
    2 Gb
    Intel Graphics Media Accelerat
    15.4" Wide Screen XGA+ display with TrueLife™
