Vista Problem Help!
Those agents don't need to run. Google just in case - setpoint, cisco, hp. Try these steps before a restore.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Try the above steps.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
What should I disable in the startup?
HI. Give us a list of everything in startup and we can go from there. Anything with Microsoft you don't need to mention, as you will keep this.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
You shouldn't need the cisco, hauppage, or logitech autoruns. Google them just in case. Use autoruns if you think there are more options to disable.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
