My new build is driving me crazy. Specs are down below. The problem is that the machine freezes randomly, anywhere from 10 minutes to hours after reboot. It just locks up, mouse won't move, task manager won't open, nothing. I have to reboot. There are no events in the event viewer that correspond to this freeze-up. Original build used all the drivers off the mobo disk, and 2 HD's in RAID1. I called MS support and the first man took over my machine and did all sorts of things to "improve performance"("Your PC will work PERFECTLY from now on!"). After that it would do nothing but BSOD, even while trying to get into safe mode. I reinstalled onto a single drive. I got every up to date driver I could, Nvidia graphics, Intel ICH10 chipset, JMicron controller, Realtek HD Audio, Realtek NIC, asus monitors. No difference. I pulled out the RAM and did it with 1 stick--no difference. I set the BIOS to 9-9-9-24 and 2T, 1.5V as spec'd. It passes memtest inifinitely. I tried MS Support a second time. He ran some DOS deal (scf? skf? scannow) which found nothing. The Vista Diagnostics supposedly found and fixed issues, but he did not share those issues with me. It froze 40 minutes later. They are calling back tomorrow to see if it worked. I will gladly take any and all suggestions at this point. I have no idea where to turn next!
Thanks
Thanks
- Self Built
- i7 920
- Biostar Tpower X58
- 6GB G Skill F3-10666 DDR3-1333 CL9-9-9-24 1.5-1.6V
- Asus 9800GT
- none
- Asus 223W
- 1680x1050
- 2xWD 500GB
- PSU
- Antec Signature 650W
- Case
- Coolermaster HAF
