Vista Home Premium x64 and Spamfighter
pushticat
I get a lot of spam and would like to use Spamfighter to reduce it. Unfortunately it does not come in a 64-bit browser version so I cannot use my Windows Mail. Spamfighter works with Thunderbird 3.0 which I absolutely hate. Does anyone know how to get Spamfighter to work with a 64-bit mail client? Or can I get rid of Windows Mail and install Outlook Express instead. All help welcomed and appreciated.
Alan
Ok for a start it is hard do get rid of windows mail because it is a default program that comes with Vista.
Hope this Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
That would be best Just don't use windows mail again ;)
    AMD HD Radeon 6870
    Novatech Night
Well you can't remove Windows Mail, but you can install Outlook (or express) and set that as the default email client. Then you can install Spamfighter
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
