Vista Home Premium HP Presario F572US, Wireless indicator light stays orange
Slainthrax
Recently My laptop has started acting strange. I can no longer connect to Wireless networks. Nor can I even detect them. On the front of my computer theres the switch to turn the wireless network on or off, regardless of the position the switch is in, I cannot see or connect to any wireless networks. I have tried dowdloading the drivers from the HP website but that does not work, I had also tried updating drivers through the computer management snapin.
If anyone could give me some insight on this it would be greatly appreciated.
`Spencer
You have to go to the manufacturer about this problem. Manufacturers with systems like that that have special programs and buttons, you have a low chance of finding a specific fix to a vendor-specific problem from a non-vendor-specific board.
Myself, I'd recommend a system restore to a prior restore point, one where you know your computer worked.
    Hewlett-Packard dv6936us
    Intel Core 2 Duo "Merom" T5750, 2 GHz, stock clocking
    stock Quanta 30D2, v.792E
    4 GHz, 667 MHz bus speed
    NVIDIA GeForce 8400M GS, stock
    stock Realtek software-based
    stock 15.4" widescreen
    stock 1280 X 800
    stock Toshiba MK2546GSX and a Western Digital 1TB MyBook
    stock
    stock
    stock plus Rocketfish model RF-LAPCOL
    stock Synaptics Pointing Device
    stock
    Ludicrous Speed (~10.9 Mbps, more or less)
    Browser: Namoroka v1.9.2.3666 64-bit build. Computer specs: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01485288&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3747246 I like chocolate milk!
Run HP Health Check.
Also, update your BIOS and your Ethernet drivers.
The BIOS updates and correct Ethernet drivers for your computer can be found here.
And this might be your problem.
    stock 1280 X 800
    stock
    stock
    stock
