Vista Hibernation Problems?
Jaffa1978
Hi guys long time since I've been on,was wondering if any1 could help me,my niece's Laptop is going into hibernation when she go's to log on.As far as i know vista isnt starting up at all.she's using vista home premuim 32bit.Thanks:)
    Own
    AMD FX 8120 Black Edition,3.1GHz oc'd to 4GHz
    Gigabyte GA-990FXA-UD7
    Corsair Vengeance 12GB DDR3 1600Mhz
    EVGA GTX 570 HD SuperClocked
    24" BenQ EW2430 LED Monitor
    1920x1080
    2TB Seagate ST2000DM001 Barracuda 7200,SATA 3 6GB/s.
    128GB OCZ Octane, 2.5" SSD.
    850W Powercool PCPC850AUBA
    Xclio Touch 767 Full Tower,With Touch Panel.
    Antec Kúhler H2O 620 Watercooler
    Razer Arctosa Black Edition Gaming Keyboard
    Sharkoon FireGlider Gaming Mouse
    Virgin 30-35Mb/s
    Krator N4-21U26W Neso4 Avante Garde 2.1 Speaker
For how long you've been facing this issue?
You can try a system restore from WIN RE.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
its only since today its been happening,she cant get on to do a restore,it just go's into hibernation when she signs on:huh:
    Own
    1920x1080
    Virgin 30-35Mb/s
Boot from Windows Vista DVD and then Click Repair Your Computer on the Installation screen and from there you can run system restore. Also, try to boot the system in safe mode to see if the issue persists.
    Compaq
    15"
    160 GB WDC
vista was pre installed i dont think she has the disk?
    Own
    1920x1080
    Virgin 30-35Mb/s
Hi Jaffa1978. Seems like a 3rd party program is causing vista to hibernate when she logs on. As suggested by Dinesh, boot to safe mode with command prompt and if it lets you login, type rstrui to open System Restore.
    Intel Dual Core 3 GHz
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
thanks she's bringing it over to my house in a bit,I'll try that and post back later.Thanks guys for the help :)
    Own
    1920x1080
    Virgin 30-35Mb/s
You are Welcome Jaffa. I hope it should work fine.
    3 GB DDR 2 667 Mhz
    ATI X1550 256 MB
    Samsung 19"
    80 GB IDE Samsung.
    iBall
    iBall
    2mbps
Hello, same problem over here. (I have this topic found by Google)
Spec. HP 550 intel chip 965
tried with:
Windows XP Pro SP3 (Fully updated
Windows Vista Basic (Pre install)
Windows 7 Build 7100 (Fully updated, and drivers from intel tested)
Please help...
Thanks Mario, Netherlands
Solved: Photo
GeTaljbLO_OegYhMSVmasg
