Vista having problems. HELP!!!
pngzhengli
Recently I have run some registry programs like RegCure, Registry Mechanic, CCleaner, etc and I'm not sure if it affects my system.
1) Most of my programs in the Start menu are missing. Below are some of the examples:
a) Under "Accessories", I can only see Bluetooth File Transfer Wizard, Command Prompt and Run.
b) Under "Games", I can only see Game Explorer
c) Many programs shortcut like Window Defender, etc are missing.
d) I still do not know what else are missing.
2) Windows take some time to shut down and startup and also running of programs.
3) Previously I was able to watch video online but now it shows "Done, but with errors on page." I click to show details and it says the following:
"Problems with this Web page might prevent if from being displayed properly and functioning properly. In the future, you can display this message by doubling-clicking the warning icon displayed in the status bar."
Line: 66
Char: 3
Error: 'Table3' is undefined
Code: 0
URL: http://www.thaitv.tv/TH/Player/Default.aspx?
Productid=2213&discsid=55144&vtype=lmv&fav=0&quality=low
4) I have 1,491 problems affecting my Windows performance which I do not know how to solve. I had attached a copy of the Event Logs and the Reliability and Performance report.
I sincerely hope someone can help me with my problems. Thanks!
You really screwed up pngzhengli.
Your best bet is to get your windows DVD and just reinstall everything.
And in the future leave the registry cleners alone. They are dinosaurs in the new OS age. Vista does not need them and as you can see they can, and do more harm then good.
You could try a restore point, but I'm betting that they are MIA as well as your programs.
Live and learn.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA 1 250GB Western Digital SATA 1 200GB Maxtor SATA 2x160GB Western Digitals SATA 1 320GB Seagate External 1 120GB Western Digital External 1 80GB Westen Digital External 1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
What kind of laptop is it?
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
I am sending you a private message.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
joel406,
While I agree that users should avoid Registry cleaners unless they know what is going on, they are certainly not "dinosaurs in the new OS [Vista] age".
Vista can have many of the same Registry issues that XP has. Registry cleaners have their place in the right hands.
S-
    Intel E6600 @ 3.0 GHz
    EVGA nForce 680i SLI (NF68-A1)
    4GB - CORSAIR XMS2 PC2 6400
    EVGA GeForce 8800 GTS (640MB)
    2 - Seagate Barracuda 7200.10 (320GB) 1 - Seagate Barracuda 7200.10 (500GB)
Sorry, your wrong.
But this is a free world(IMO) and your right to yours is worth dying for.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
Sorry, your wrong.
joel406,
You might want to doubt your infallibility just a bit.
I have personally used Registry cleaners on Vista to fix problems that would otherwise would have required a new install. So you can say that the Vista Registry never needs a Registry cleaner, but, in my experience, that is simply untrue.
S-
Sorry, your wrong.
joel406,
S-
Which do you recommend?
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
I think CCleaner is pretty safe. So is TuneUp Utilities 2008. I have used both to fix damaged Vista Registries.
I think nCleaner is dangerous to use on Vista....
S-
Well anyway guys, can we help the op now!
Hello pngzhengli.
I believe you can follow these instructions below to do a "Factory Recovery" on your machine.
Be advised that this will bring the machine back to a state when you first got it.
You will lose any data you have on it; but it sounds like you are beyond that being a concern!
Start with the machine off, press the power button, as soon as you do that start tapping the F11 key.
That should take you to the "Recovery Center". When there just follow the prompts.
It is pretty much self explanatory.
If your first option is system restore select no, which should take you to system recovery.
You want to try system recovery not system restore, unless you have good restore points!
If your first attempt to boot into F11 doesn't work, try again.
I hope this helps you; please keep us informed!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
