Solved vista hard drive fix
bgtiger
i have vista home os system
its a dell inspiron 1501
2 gigs of ram
and a 80 gig hard drive
but when i log onto my system it says i have a 60 gig hard drive
can anyone help i just want to find out why it does this:D
Post a screenshot of Disk Management.
To get to Disk Management:
Click Start Orb>Rt click Computer>click Manage (wait a few seconds for a new window to open )>click Disk Management in the left pane - in a couple of seconds you will see your hard drive partitions.
To post a jpeg screenshot, click the Quick button , then Go Advanced and follow step 8 onward of this tutorial
http://www.vistax64.com/tutorials/148532-how-use-snipping-tool-vista.html
Hope it helps
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Hi Bgtiger, and welcome to Vista Forums.
Since you have a OEM computer, the other 20 GB may have been used for a D: recovery partition. Disk Management will show this if this is the case.
Yes, I expected it to be , they are often 9 or 10 gb. With some manufacturers, there is also a small "system health" partition.
SIW2
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
You're welcome bgtiger. Glad you got it sorted. :)
