I installed Sphinx Software's Vista Firewall Control about an hour ago and it worked perfectly until i rebooted my computer couple minutes ago to refresh my memory preparing to play a game.I got the message that Vista Firewall Control Service is not running at startup.Oh,i tried turning off windows firewall and rebooting incase of a conflict,but same problem.I'm running Windows Firewall Control 64-bit version on Vista Home Premium 64-bit SP1.Anyone who can assist me with my problem i'd appreciate it.
is your new firewall listed under the startup items? start/all programs/accesories/run in the resulting box type msconfig and hit return , look under the startup tab and see if your firewall is listed there also look under the services tab and put a check in the "hide all microsoft services check box" then see if your firewall is listed there
fyi restarting Vista will do nothing for your memory , all it will do is restart Vista Superfetch (it precaches your most used programs into memory for faster starting) its not actually a good idea to run a game while superfetch is doing its thing immediately after a startup as it actually impacts on your performance ingame , your better of waiting 5 minutes till its "done its thing"
Vista is VERY good at freeing up memory when its needed by any application especially a game (trust me ) a reboot is not needed.
Exactly the same applies if you have superfetch disabled (not really a good idea its actually pretty usefull)
