Vista errors and slow icon generation
mortalcombat
Vista is taking a lot of time to load shortcut icons and file icons.. Why is this happening? My laptop is 1 month old
Also my laptop is hanging every minute or so for 1 sec
dunno if this will help but I found errors worth reporting from the Event Viewer:
Log Name: System
Source: disk
Date: 3/16/2009 11:07:15 PM
Event ID: 11
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
The driver detected a controller error on \Device\Harddisk1\DR2.
Log Name: System
Source: Microsoft-Windows-Kernel-Processor-Power
Date: 3/15/2009 9:02:59 PM
Event ID: 7
Task Category: None
Level: Warning
Keywords:
User: SYSTEM
Description:
The speed of processor 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report.
Same for processor 1
    Sager NP8660
    Core 2 Duo P8700 2.53Ghz
    M860TU
    4GB DDR3-1033
    512MB 9800M GTS
    WSXGA+
    1650x1080
    Hitachi 320GB 7200RPM
    10 Mbps
First, have you been using reg cleaners to try and improve performance? these can cause Windows corruption.
Your problem(s) may be a result of Errors on the Drive, and fragmentation.
You may want to update your (SATA?)/RAID controller, and BIOS firmware if available. Check Windows updates for applicable drivers/updates. Keep going back untill no updates are available for your system.
Another thing, if applicable, is removing Crapware that came pre-installed, and any startup programs not necessary.
Try this to also improve performance and speed:
http://www.vistax64.com/tutorials/165576-how-make-vista-more-responsive-faster.html?filter
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
I always defrag my drive.. I haven't ran a disk check in a while and I'm going to check for new drivers..
I have removed everything crappy from my laptop so this isn't the problem...
Is the hard drive speed reduced if it is more full?
    Sager NP8660
    M860TU
    4GB DDR3-1033
    512MB 9800M GTS
    WSXGA+
    1650x1080
    10 Mbps
default defrag in Vista leaves alot of fragmented files behind- try a full defrag through Administrator:command prompt Defrag c: -w
a fragmented/error strewn drive will severly impact performance; while Corruption may result in a non-bootable system, and loss of Data (so backup).
Check your drive for file system errors and bad sectors
Your problems may also be the result of Corrupted drivers, and/or Windows itself either due to malware or Registry Cleaners-If that is the case only a reinstall/restore may fix your problems.
Again I suggest:http://www.vistax64.com/tutorials/165576-how-make-vista-more-responsive-faster.html?filter as this will determine if you have drive corruption, and scan here for malware:http://www.vistax64.com/system-security/162362-antivirus-scanners-internet-security-tools.html scan will multiple online scanners, as not every antivirus will catch everything.
I suggest the following online scannners:
Eset NOD32
Kaspersky
Symantec Norton
and Installing Avira (If using free antivirus)
For nore info on the best performing Antimalware programs , and their performance in Lab testing against current malware infections/threats see:http://www.vistax64.com/system-security/172321-vista-sp1-antivirus-performance.html
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
