Vista 64 Geforce 260 driver problem
lambofgod1234
Hi I just reinstaleld windows vista 64 ultimate and I installed the gpu driver and when I restart when the vista loading screen is finished it goes to a blank screen for about 5-10 secs and then the moniter just says their is no connection or something I have never had this problem
amd 9850 stock 8gigs corsair xms2 evga 260ssc 150velocity raptor 1k antec psu m3n78pro mobo
merry xmas and happy holidays
Check that the card is seated properly and you have the 4-pin connector connected to the card.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Also, *which driver did you install? I have one of those SLI'd with a stock 260 (and am using eVGA's Precision utility to OC both to 636 MHz / 1107 MHz / 65% rpms) and have not had a single problem with any of the drivers, neither the 'current' 180.48 nor the Beta 180.84 and 181.00
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Well first I went to the website and installed the 180.48 and when it gets to the login screen it just goes blank so i installed windows again because i have no idea how to get by that so i tried the cd that came with it i think its 174 or something but yeah i had to re install vista and this is my second time doing this and i have not had this problem before and to the other answer yes the two 8 pin conectors are plugged in I have 2 other ones that came with my psu should i try those?
Thanks for the support on the holiday
where are the 8 pin connectors coming from? although I doubt that power here is an issue as if the card were underpowered you'd get a nice big fat message on the screen complaining about power as soon as the system were powered on....
Right now, are you on a brand new Vista installation with no drivers installed?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
*from* the Internet? Again, *which* version?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
The motherboard drivers are from the cd the chipset is 4.6.4.0 the audio driver is 6.0.1.5618 the hdmi driver is 1.00.00.23
Right now on the video settings it says generic-non-pnp on standard vga graphics adapter and i am using my 260 connected by a dvi cable
I have no real video driver on here i guess
thanks
I asked about the driver version for the GTX260. The one that you tried - the one that failed.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
OK, so you are using a brand new install of Vista at the moment, with no video driver - what else *have* you installed? And what does Device Manager say you have under your Display Adapter?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
No antivirus of any kind? No download manager, no toolbars, nothing else?
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
And yet your machine produces problems when you install the driver. Do you get a message stating that this drive is not signed, asking you to continue or not, when isntalling it?
Have you tried downlaoding the driver again, perhaps something got corrupted in your initial downlaod....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
