Vista 64 and card reader
ccengineer
Hello there. I have a Vista 64 OS on an HP m9100z computer. It has an internal card reader. The reader used to work fine. But now (have live update on) the Card reader does not work properly. The reader is detected but with the yellow warning sign. When I plug in a card it does not show up in the drives and the warning sign would still be displayed. Removing the drivers and rebooting did not change the issue. But if I remove the driver and plug in a card and redetect or reboot while the card is in the reader it works properly. Any idea what is happening. The reader is an HP 10 in 1 reader.
I changed the reader thinking it was defective. But I still have the exact same problem.
have you looked in device manager
also see if you can update the drivers
    home built
    Intel Core i7 920 2.66ghz @ 3.67ghz 1.3v
    ASUS P6T Deluxe V2 iX58
    6GB (3x2GB) Corsair Dominator DDR3 1600MHz@1400mhz 8-8-8-24
    BFG GTX 285 OCX
    on board
    samsung t220 sync master
    1TB samsung
    Corsair HX1000W
    antec 902
    Zalman CNPS10X Extreme Ultra Quiet x3 120mm + 200mm fans
    Microsoft Wireless Laser Desktop 7000
    6mb
    LG dvd-rw, LG GGC-H20L blueray player, Sony 2.1 speakers system, HP photosmart c5180 All-in-one Printer/Scanner/Copier (network conected) NetGear DG834G v4 ADSL Modem/Router (Ethernet) netgear GS608 8 port switch WEI Score: 5.9
I used device manager deleted the cards and re added them, same thing. I downloaded drivers for card readers and still the same issue, installed service pack and hot fixes and still no change.
is the computer still under warranty ???
    home built
    BFG GTX 285 OCX
    on board
    1TB samsung
    Corsair HX1000W
    antec 902
    6mb
I had a similar problem after re-installing Vista Home basic 32 bit. My sd card reader had the same yellow exclamation mark. I did all the right things and none worked. I finally broke down (almost crying) and BOUGHT, yes you read it right, BOUGHT, some software to update my drivers and it worked wonderfully. Updated everything on my system. here is the url
ParetoLogic - Products - ParetoLogic DriverCure
I just tried DriverCure. It found a few newer drivers, but most of the ones it found were not compatible with my system.. Also, my Icons are still missing from my internal card reader. I have tried another brand of card reader, still not changes.
    Dell XPS 730X h2c
    Intel i7 965
    6 GB
    ATI Radeon 4870 x2
    Creative SB X-Fi
    Dual Dell 2709W
    1920x1200
    4 1TB in Raid 5 2 1.5 TB
    H2C
    Microsoft Wireless 6000
