Solved Vista 32 bit or Vista 64 bit
mahojazz
Hi all,
i am getting a new laptop and it comes with 4GB ram and I am given the option to select either Vista 32 bit or Vista 64bit OS. Is it recommended to go for 64bit vista to use tat extra 800mb ram or i should stick with 32bit vista for better compatibility?
Also, will i be able to run 32bit apps in 64bit vista? Thanks alot
Hello Mahojazz, and welcome to Vista Forums.
If you have 64-bit drivers available for all of your devices, then you should be fine since most 32-bit apps will run just fine in 64-bit Vista. The only exceptions are usually utility programs. Double check to make sure that your apps support 64-bit (x64) first though.
This may be an interesting read to if you like.
http://www.vistax64.com/vista-news/99613-64-bit-more-than-just-ram.html
Using x64, and so far the only casualty has been the Google Sidebar (gagdets). The Vista Sidebar works just fine in it's stead. :D
Edit: oh yeah, had to find a new atomic clock utility as well.
    BYOB
    AMD Phenom 8750 Triple-Core
    MSI K9A2-Neo-F
    2x 2GB Kingston DDR2 PC2-6400 400MHZ
    XFX nVidia Geforce 8600 GT
    Onboard Realtek
    LG L226WT 22" Wide Screen
    1600x1050
    SATA 3 Seagate 500GB SATA 3 Seagate 500GB
    Antec P180
    Fans and stuff...
    Logitech EX100
    Logitech EX100
    High-Speed Cable
oh, its confirmed, i am getting the new laptop with vsita home premium 64bit. Hope everything works fine. BTW, Mcafee Internet security works in 64bit? I will be installing a couple of 32bits apps as well. Looks like i will be asking more n more questions in the forum. ;-)
Yes, McAfee Internet Security will work on the 64-bit Vista. :)
