My Sys:
32 bit Dell 8400 Dimension 3.4 ghz, 925 chipset and HT technology. 4gb of ram (3.4 showing), NVIDIA 6800 w/256 ram. SB Audigy Z2 sound card. BIOs is also current and nothing to tweak in there either...Performance is set to "power user."
I did a CLEAN install of Vista 32bit Ultimate. All drivers are up to date and all Vista updates done to include SP2.
After my final updates I did a defrag, a virus scan using CA Anti-Virus suite and also used CCleaner to fix any errors during the install and clean up any orphans etc.
I went through many Vista tips and tricks sites and diabled all the useless programs/mem-hogs etc. and also went thru the "Services" section and disabled the appropriate programs not required for a home user.
Problem:
After all the tweaks etc, my system seems to come to a halt (I get the spinning wheel for the cursor) and the system just spins for about a minute or so until something in the background lets go and then the system starts running again. Consistently does this...it just acts like it's running on low memory when there is plenty!!!
*No noise from the CPU indicating anything running, just quiet and then after a short while...the system just cranks back up like whatever's causing this is done and lets the OS get back to whatever it was tasked with doing before it just went idle...Hybernate is NOT enabled.
Task manager does not show anything hogging resources to cause the system to go into a holding pattern!!!
My mem-manager (Windows Vista Service Manager) states I have 69% mem available but the OS is running like I only have 500mb installed!
I've checked eveywhere I can imagine to find out WHY this happens but no luck. I've disabled all kinds of crap (per Vista articles on optimizations) and it makes no difference!
I removed Win XP MCE only as I wanted to upgrade to a more current system and had this extra Vista OS available. WinXP MCE ran fine and never lagged on me EVER!!!
I'd rather NOT go back to WinXP MCE as I like some of the newer featurs of Vista.
*This also happened with Win-7 32 bit....tried that OS as well...I can only guess these OSes were only ment for Core 2 Duo systems?
Any insight appreciated...
Problem:
