Virus??? Please help...
dinesh
Vista Expert
Hi guys i m in a serious problem here. My antivirus is turned off and i cant turn it on. I m unable to update windows. When i click on malwarebytes, UAC comes up but when i click Continue, it wont come up. I assume that its a virus but i scanned my system from Defender and NOD32 and the results are ok. I dont understand what's going on.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Thanks leslie, it was all because of the DNS servers. i use a fixed ip and DNS server and it was changed. so i did put my old DNS server back and its now working. but still when i click on Malwarebytes, it wont open, i have reinstalled it twice but it wont open. any idea?
    Compaq
    15"
    160 GB WDC
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
hey i just installed spybot and the file is downloaded on my desktop. but it shows as an unknown file. how do i open it? when i double click it, its giving me some programs thru which i can open it like IE, vlc, etc. how do i open this .exe file?
    Compaq
    15"
    160 GB WDC
    Acer Aspire 5920gmi notebook
    NVIDIA GeForce 8600M GS
    Realtek
    crawl
Hi Dinesh,
Sounds like a problem with the .exe file association,
you could navigate to this key :
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.exe\UserChoice
and delete it.
Or merge this .reg file
View attachment Remove-exe-UserChoice.reg
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
i was able to navigate to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.exe\ but there was no UserChoice. I merge the .reg file. i m downloading spybot again. i will let you know if it works.
    Compaq
    15"
    160 GB WDC
You should have this :
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.exe\OpenWithProgids\exefile
with hex value of 0
If not merge this:
View attachment exe-filext-default.reg
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
It worked, thanks siw.
    Compaq
    15"
    160 GB WDC
You're welcome.:D
I presume you mean the second .reg file worked.
Strange - don't know where that disappeared to .
Might have been removed by something nasty to stop you running malware removers.
Better check with Malwarebytes and SuperAntispyware to be sure.
Click on the FREE edition on this page:
http://www.superantispyware.com/
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
Well, what happened was i downloaded a file and when i clicked to open it, a black command prompt windows flashed and it disappeared.
Since then whenever i open malwarebytes, a black windows pops up and disappears.
I tried running superantispyware, NOD32, i reinstalled malwarebytes, etc, nothing worked. I also ran HJT and an entry kept coming up even if i delete it. Finally i gave up and reinstalled OS.
What i learned is: Beware from torrents.
    Compaq
    15"
    160 GB WDC
