Virus help please!
fourthwave
when I try to access the personalize file or the system file from the control panel I get a explorer.exe application error. also when I try to acess any files in the c:/ drive. I think it might be a trojan ataccking explorer but I dont know what to do. any help would be greatly apreciated
Hello there and welcome to vista forums!
Have you done any scanning with your AV?
Have you downloaded anything recently?
    Neo Vivid V2121
    Intel Pentium Dual CPU T2390 @ 1.86GHz
    SiS M720SR
    Built-in
What AV are you running?
I would recommend running a scan with Malwarebytes.
Let's see what Malwarebytes will find in your system.
    Neo Vivid V2121
    SiS M720SR
    Built-in
    Neo Vivid V2121
    SiS M720SR
    Built-in
Malwarebytes' Anti-Malware 1.43
Database version: 3468
Windows 6.0.6001 Service Pack 1
Internet Explorer 7.0.6001.18000
01/01/2010 21:50:49
mbam-log-2010-01-01 (21-50-41).txt
Scan type: Full Scan (C:\|D:\|E:\|F:\|)
Objects scanned: 165261
Time elapsed: 1 hour(s), 8 minute(s), 24 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 1
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\forceclassiccontrolpanel (Hijack.ControlPanelStyle) -> No action taken.
Folders Infected:
Files Infected:
this is what the maleware search found. what should I do. malware has an option to remove the 1 item it found. should I remove it
So the scan came up clean... Does it only crash in those folders?
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
And the error is Windows Explorer has encountered a problem and needs to restart? If so, does it crash when you right click then go to personalize?
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
I removed the file but it didnt fix the problem
Hello fourthwave what you refer to here is it the infected registry value that Malwarebytes found that you removed?
    Hewlett Packard, compaq presario CQ60-305AU
    AMD Athlon QI-46 2.1 Ghz
    Wistron 303C
    2048 Mb DDR2 SD Ram
    NVidea GE Go Force 8200M G / 256Mb dedicated grapics memory
    MCP78S NVidea High definition
    15.6" High Definition Brightview Widescreen
    1336x768
    Toshiba MK2555GSX ATA
    Synaptics PS2/Touchpad
