Viewsonic vx2835wm
OldShoeLace
I've downloaded and gone through the Device Manager install of the Vista signed and unsigned drivers from Viewsonic. Choose the vx2835wm as the monitor and... "file not found". Viewsonic support sends me to a link that says "no drivers available" and then says to download their Vista 64 package I've been doing since day 1. (been doing this and all suggestions since Nov 2007)
Vista Ult. 64 uses its default non-pnp drivers where I have my 1920x1200 native res. with everything but gaming (the reason for purchasing this monitor). I can't get anything higher than 1600x1200 (in gaming) and well, its fuzzy. Can't use windowed mode, OS drivers stop functioning and reload frequently. I've set the res. in the nVidia panel to 1920x1200, set the game ini file to 1900x1200 but it still will only work at 1600x1200 although the games support the higher resolutions.
Is there anyone here that uses this monitor that has found Vista 64 drivers that work? If not, is there a 28", or even 30, that has Vista 64 drivers that will work at native resolution with any program or game?
I am ready to sail this monitor out the third floor window and buy another if I can't get a solution for fixing this one so need recommendations on other monitors as well.
Thank you
2x8800 nvidia ultra's sli'd
extreme core 3.0
4gb corsair
evga nforce 780i
thermaltake 1000 watt ps
sb extreme gamer fatality
Dwarf I don't see your reply here although I did get an email that you posted.
The following link is to the signed standard Viewsonic monitor driver for Vista 64-bit. This driver should be installed with administrative privileges. For games, you might need to adjust your settings such as anti-aliasing in order to be able to use this resolution. The higher certain settings are, the lower the maximum resolution that is available. This is just a matter of trial and error, bearing in mind that higher resolutions require more working RAM on the graphics card and also a card of sufficient power to yield a decent frame rate at these settings.
Dwarf
I did download those many times each time it was updated by Viewsonic. It goes through the device manager wizard fine and then 'file not found'. However, someone did message and email me their driver folder from the monitor cd and it worked. Apparently my cd was a bad one. So all is well and working. Games are working great with the right resolution now.
OSL
Hi there, I am having the same issue with Vista Ultimate x64.. I have a viewsonic p220f and I am unable to install the driver. Signed drivers do not detect my monitor and unsigned drivers require me to manually update the driver through device manager but I get a 'file not found' error when trying to manually update. Could you provide details on how you fixed this problem or where I can get a working driver? Thank you very much.
I have the same issue with my va2012wb.. I've tried all of the vista x64 signed and unsigned, also I tried the generic non-os specific drivers, I never finds the monitor. I also have not been able to successfully manually choose the monitor or find the error
So did anyone get drivers to work with their monitor and x64? I have p220f and same problems. If someone can email me the drivers that would be great. PM me for email address. Thanks...
