floridayank
I am a bit lost, but trying to fix my friends computer. Thought he just had some crazy virus, but I think it is a driver problem, or a failing video card. Not real good with Vista, so here I am.
He told me it was powering down within 5 minutes of booting up. I have had it up over 24 hours atm. However, the VGA input does not display my monitor. It "detects" it, as I hear a noise when I plug it in, but no display. For some video game, he has a DVI to VGA adapter. This allows me to get my monitor to work on his 2 DVI outputs. He also has an s-video output, but short of my televisions in another room, I dont have anything s-video to test it on. Is there and driver that controls just the VGA input, can his video card be failing but still have the other 2 inputs (not counting the s-video, which is unchecked) be failing, or is it a "broken" VGA input (pins loose inside, or connection problem)
Just want to know if there is any fix before I crack it open and start poking around.
Thanks a lot, hope everyone is not too bloated from all the turkey yesterday!
