Video card difference.
I found a cool PC game I want to buy, I passed all the requirements for it, except the video card. It calls for a GeForce 6800 series or greater. I have a GeForce 6150. Would this affect the game at all? Thanks.
    eMachines ET 1161-05
    AMD Athlon 64 X2 6000+ 3.0 GHz AM2 Dual Core
    3gb
    Galaxy GeForce GT 430 - 1gb DDR3 - 128bit Memory Interface
    Realtek HD Audio
    Samsung 23" LED, 1920 x 1080 resolution
    1920x1080
    160gb Seagate
    Cool Master Extreme Power Plus - 500watts
    APEVIA X-Trooper Case w/ Side Window-Blue
    4, 120mm fans. 1, 200mm fan. Sunbeamtech Rheobus-Extreme
    Logitech k800 Wireless Illuminated Keyboard
    150mbps
    Linksys WUSB100 Insignia 2:1 Sound system.
Probably....the 6800 is a dedicated card and yours is integrated. It might be able to run on lower settings. You need to try.
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
Hm. Ok. If I buy a aftermarket video card, will i have to anything else? Or just put it in and it will work?
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
do you have an empty ''PCIE slot'' on your motherboard..??
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Uh. I have no idea. I got the computer for christmas, it's all stock. It's a eMachines et1161-05.
If that helps........maybe you can look it up?
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
ok.... according to the specs (& the fact you actually have space in the case), here's a few options that will really improve your gaming experience... ;)
9800GT
HD5670 DX11
none of these cards require additional power, & will both be night & day difference from what you have now..
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
:shock:
More expensive then I thought.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
i suppose you can go cheaper if you want, but the cards i listed above are GOOD gaming cards which have low power consumption at a great price..
TBH mate unless you have a half decent GFX card, i wouldn't even put myself through the torture of trying to game..
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Yeah. I just wanted to try a computer game. Saw one that looked cool. but if it costs too much, I won't even bother.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
what game was it..??
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Crysis.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
LMAO....... :eek:
forget it mate, you'd need more GPU power than i suggested, in fact you'd need a complete H/W transplant to run it.
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Yeah, I heard it has very high requirements. Whatever. I never played a computer game before. I don't need it then.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
You can still invest in a card to do more that what you think. I know they sell cheaper ones at Staples ATI/Nvidia. They arent as expensive as most of the higher end cards and make the whole pc experience alot better.
BUt about Cyrsis...I wont even try it on my high end laptop...you need to really but a whole system together to play that one the best possible, or even the lowest end.
There are alot of games out there on the market so try them out and work from there.
    17" Laptop Screen
Do you know of any good computer games that my stock computer will run?
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
What genre do you prefer?
    17" Laptop Screen
Hm. Games such as COD, Crysis.......I don't know the genre. just nothing like WoW.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
battlefield 1942, combat arms, combat arms is free by the way
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
For most of the game today you can play them. If you are trying Assassins Creed, COD 4, Left 4 Dead, Bioshock then you can probably play them with what you have. At least on medium to low settings.
If you upgrade the graphics you could play most directx 10 games with a 256 MB graphics card.
    17" Laptop Screen
I got Combat Arms. Pretty cool game! I am able to run on high quality. But..is there a career mode? Seems to be only group missions.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
